[postgis-users] Building PostGIS from Sunday CVS..without PostgreSQL Sources...OK ! ! !
Jean David TECHER
davidtecher at yahoo.fr
Sun Apr 24 10:39:38 PDT 2005
Hi Sandro and PostGIS'ers,
Last Sunday, I decided to compil PostGIS from CVS (form sunday in the afternoon)...
Since the goal is to build PostGIS WITHOUT PostgreSQL sources but from the binairies installed on the computer
the tests on Windows for me is OK...Successfull...I did it for PG 8.0.2, Geos 2.1.1 and Proj 4.4.9
The only changes -I had to do - were to make few changes on:
-1/ postgis/Makefile.config.in
- 2/postgis/lwgeom/Makefile
- 3/postgis/loader/Makefile
For each file, I used
ifeq ($(findstring MINGW,$(MSYSTEM)),MINGW)
XXXXXXXXX
else
XXXXXXXXXX
endif
The changes in files are at the end of this files (sorry, I didn't at enough times to make patch... :-[ ....)
Since i'm not at job on Monday but Tuesday, I will do a resume doc next Tuesday
NOTICE: For creating postgis doc, I need to have docbook-xslt-stylesheets, xlstproc and icon.dll installed on Windows..Nevermind
Just 3 downloading to do.
cvs -d:pserver:cvs at postgis.refractions.net:/home/cvs/postgis login
cvs -d:pserver:cvs at postgis.refractions.net:/home/cvs/postgis co postgis
cd postgis
autoconf
configure --enable-autotconf --with-geos=`which geos-config`
make
make install
cd regress
make
Regression Tests, Loading some data with the laoder (...) work fine...
========================================[postgis/Makefile.config.in ]==============================================================
# Configuration Directives
# We recommend that you install the Proj4 and GEOS libraries
# referenced below to get the most use out of your PostGIS
# database.
# Set USE_PROJ to 1 for Proj4 reprojection support (recommended)
# Reprojection allows you to transform coordinate systems
# in the database with the Transform() function.
# Download from: http://www.remotesensing.org/proj
USE_PROJ=@USE_PROJ@
PROJ_DIR=@PROJ_DIR@
# Set USE_GEOS to 1 for GEOS spatial predicate and operator
# support (recommended).
# GEOS installation directory defaults to /usr/local,
# set GEOS_DIR environment variable to change it.
# GEOS allows you to do exact topological tests, such as
# Intersects() and Touches(), as well as geometry operations,
# such as Buffer(), GeomUnion() and Difference().
# Download from: http://geos.refractions.net
USE_GEOS=@USE_GEOS@
GEOS_DIR=@GEOS_DIR@
# Set USE_JTS to 1 if you have libjts installed.
USE_JTS=0
JTS_INCLUDES=@JTS_INCLUDES@
JTS_LIBDIR=@JTS_LIBDIR@
# Set USE_STATS to 1 for new GiST statistics collection support
# Note that this support requires additional columns in
# GEOMETRY_COLUMNS, so see the list archives for info or
# install a fresh database using postgis.sql.
# This option is useless for builds against PGSQL>=80 (stats
# are always gathered in that case, and you don't need additional
# columns in geometry_columns).
USE_STATS=1
# Set AUTOCACHE_BBOX to 0 if you want finer control over
# bounding box computation and caching for your geometries.
# If you do, bbox computattion strategies are listed in
# the file lwgeom/BBOXCACHE_BEHAVIOURS, but don't expect
# them to be easy nor consistent.
AUTOCACHE_BBOX=1
# Set USE_ICONV to 1 if you want the loader (shp2pgsql)
# to support UTF-8 output.
USE_ICONV=0
# PGSQL
PGCONFIG=@PGCONFIG@
PGFEINCLUDES=@PGFEINCLUDES@
PGBEINCLUDES=@PGBEINCLUDES@ @PGBEINCLUDES@/port @PGBEINCLUDES@/port/win32 @PGBEINCLUDES@/port/win32/arpa
else
PGFELIBS=@PGFELIBS@
endif
# Docbook
XSLBASE=@XSLBASE@
# Compilers
CC=@CC@
CXX=@CXX@
# Other programs
FLEX=@FLEX@
YACC=@YACC@
INSTALL=@INSTALL@ -c
INSTALL_DATA=$(INSTALL) -m 644
INSTALL_BIN=$(INSTALL) -m 755
INSTALL_LIB=$(INSTALL) -m 755
# PATHS
prefix=@prefix@
exec_prefix=@exec_prefix@
bindir=@bindir@
datadir=@datadir@
mandir=@mandir@
docdir=@docdir@
libdir=@libdir@
libexecdir=@libexecdir@
MODULE_INSTALLDIR=@MODULE_INSTALLDIR@
LPATH=@LPATH@
# DLL
DLSUFFIX=.dll
DLFLAGS=@DLFLAGS@
else
DLSUFFIX=@DLSUFFIX@
DLFLAGS=@DLFLAGS@
endif
# END OF CONFIGURATION
# Use JTS instead of GEOS if available
ifeq ($(USE_JTS),1)
USE_GEOS=0
endif
# Test the version string and set the USE_VERSION macro
# appropriately.
VERSION=$(shell $(PGCONFIG) --version)
ifneq ($(findstring 7.1,$(VERSION)),)
USE_VERSION=71
else
ifneq ($(findstring 7.2,$(VERSION)),)
USE_VERSION=72
else
ifneq ($(findstring 7.3,$(VERSION)),)
USE_VERSION=73
else
ifneq ($(findstring 7.4,$(VERSION)),)
USE_VERSION=74
else
USE_VERSION=80
endif
endif
endif
endif
========================================[ postgis/lwgeom/Makefile ]==============================================================
include ../Makefile.config
include ../Version.config
# Default missing CXX variable to c++
ifeq ($(CXX),)
CXX = c++
endif
# Shared library parameters.
NAME=lwgeom
SHLIB = lib$(NAME).$(SO_MAJOR_VERSION).$(SO_MINOR_VERSION)$(DLSUFFIX)
SHLIB_MAJOR = lib$(NAME)$(DLSUFFIX).$(SO_MAJOR_VERSION)
SHLIB_BARE = lib$(NAME)$(DLSUFFIX)
SHLIB_LINK =
else
SHLIB = lib$(NAME)$(DLSUFFIX).$(SO_MAJOR_VERSION).$(SO_MINOR_VERSION)
SHLIB_LINK = $(DLFLAGS)
endif
MODULE_FILENAME = $(LPATH)/$(SHLIB)
# Postgis version and build date
POSTGIS_VERSION = $(SO_MAJOR_VERSION).$(SO_MINOR_VERSION) USE_GEOS=$(USE_GEOS) USE_PROJ=$(USE_PROJ) USE_STATS=$(USE_STATS)
POSTGIS_LIB_VERSION = $(SO_MAJOR_VERSION).$(SO_MINOR_VERSION).$(SO_MICRO_VERSION)
POSTGIS_BUILD_DATE := $(shell date -u "+%Y-%m-%d %H:%M:%S")
else
endif
override CFLAGS += -g -O2 -fexceptions
override CFLAGS += -fPIC
#override CFLAGS += -I$(srcdir) -DFRONTEND -DSYSCONFDIR='"$(sysconfdir)"'
override CFLAGS += -DUSE_VERSION=$(USE_VERSION)
override CFLAGS += -DPOSTGIS_LIB_VERSION='"$(POSTGIS_LIB_VERSION)"'
override CFLAGS += -DPOSTGIS_SCRIPTS_VERSION='"$(SCRIPTS_VERSION)"'
override CFLAGS += -DPOSTGIS_BUILD_DATE='"$(POSTGIS_BUILD_DATE)"'
JTS_OBJ=lwgeom_nojts.o
ifeq ($(USE_GEOS),1)
override CFLAGS += -I$(GEOS_DIR)/include -DUSE_GEOS
GEOS_RULES=detect_geos_version
GEOS_WRAPPER=lwgeom_geos_wrapper.o
JTS_OBJ=lwgeom_geos.o
SHLIB_LINK += -lstdc++ -L$(GEOS_DIR)/lib -lgeos
endif
ifeq ($(USE_JTS),1)
override CFLAGS += -I$(JTS_INCLUDES) -DUSE_JTS
JTS_WRAPPER=lwgeom_jts_wrapper.o
JTS_OBJ=lwgeom_jts.o
SHLIB_LINK += -lgcj -ljts -lstdc++ -L$(JTS_LIBDIR)
endif
ifeq ($(USE_PROJ),1)
override CFLAGS += -I$(PROJ_DIR)/include -DUSE_PROJ
SHLIB_LINK += -L$(PROJ_DIR)/lib -lproj
endif
override CFLAGS += $(PGBEINCLUDES) -DAUTOCACHE_BBOX=$(AUTOCACHE_BBOX)
override CXXFLAGS := $(CFLAGS)
# memory debug for gcc 2.91, 2.95, 3.0 and 3.1
# for gcc >= 3.2.2 set GLIBCPP_FORCE_NEW at runtime instead
#override CXXFLAGS += -D__USE_MALLOC
# Add index selectivity to C flags
ifeq ($(USE_STATS),1)
override CFLAGS += -DUSE_STATS
endif
SA_OBJS=measures.o box2d.o ptarray.o lwgeom_api.o lwgeom.o lwpoint.o lwline.o lwpoly.o lwmpoint.o lwmline.o lwmpoly.o lwcollection.o $(GEOS_WRAPPER) $(JTS_WRAPPER) wktunparse.o lwgparse.o wktparse.tab.o lex.yy.o vsprintf.o
OBJS=$(SA_OBJS) liblwgeom.o lwgeom_pg.o lwgeom_debug.o lwgeom_spheroid.o lwgeom_ogc.o lwgeom_functions_analytic.o $(JTS_OBJ) lwgeom_inout.o lwgeom_estimate.o lwgeom_functions_basic.o lwgeom_gist.o lwgeom_btree.o lwgeom_transform.o stringBuffer.o lwgeom_box.o lwgeom_box3d.o lwgeom_box2dfloat4.o lwgeom_chip.o lwgeom_svg.o lwgeom_gml.o lwgeom_triggers.o lwgeom_dump.o
#OTHERS=y.output lex.yy.c wktparse.tab.c wktparse.tab.h lwpostgis.sql
OTHERS=y.output lwpostgis.sql ../lwpostgis.sql postgis_geos_version.h
# Makefile targets
all: $(GEOS_RULES) $(SHLIB) ../lwpostgis.sql
#------------ It's for Win32 -----------------------------------
$(SHLIB): $(OBJS)
dlltool --export-all --output-def lwgeom.def $(OBJS)
dllwrap -o $@ --dllname $@ --def lwgeom.def $(OBJS) $(SHLIB_LINK) -L$(shell pg_config --libdir) -lpostgres
dlltool --dllname $@ --def lwgeom.def --output-lib liblwgeom.a
else
$(CC) $(SHLIB_LINK) -o $(SHLIB) $(OBJS)
endif
wktparse.tab.c: wktparse.y
$(YACC) -vd -p lwg_parse_yy wktparse.y
mv -f y.tab.c wktparse.tab.c
mv -f y.tab.h wktparse.tab.h
lex.yy.c: wktparse.lex wktparse.tab.c
$(FLEX) -Plwg_parse_yy -i -f -o'lex.yy.c' wktparse.lex
lwgeom_jts_wrapper.o: lwgeom_jts_wrapper.cpp
lwgeom_geos_wrapper.o: lwgeom_geos_wrapper.cpp
lwgeom_geos.o: lwgeom_geos.c profile.h
lwgeom_jts.o: lwgeom_jts.c profile.h
lwgeom_nojts.o: lwgeom_nojts.c
lwgeom_functions_basic.o: lwgeom_functions_basic.c profile.h
# Shared library stuff
../lwpostgis.sql: lwpostgis.sql
cp lwpostgis.sql ..
lwpostgis.sql: lwpostgis.sql.in
cpp -P -traditional-cpp -DUSE_VERSION=$(USE_VERSION) $< | sed -e 's:@MODULE_FILENAME@:$(MODULE_FILENAME):g;s:@POSTGIS_VERSION@:$(POSTGIS_VERSION):g;s:@POSTGIS_SCRIPTS_VERSION@:$(SCRIPTS_VERSION):g;s/@POSTGIS_BUILD_DATE@/$(POSTGIS_BUILD_DATE)/g' | grep -v '^#' > $@
install: all install-lwgeom-lib install-lwgeom-scripts
install-lwgeom-scripts:
@mkdir -p $(datadir)
$(INSTALL_DATA) lwpostgis.sql $(datadir)/lwpostgis.sql
$(INSTALL_DATA) ../spatial_ref_sys.sql $(datadir)/spatial_ref_sys.sql
#- This has been copied from postgresql and adapted
install-lwgeom-lib: $(SHLIB)
@mkdir -p $(MODULE_INSTALLDIR)
$(INSTALL_LIB) $< $(MODULE_INSTALLDIR)/$(SHLIB)
ifneq ($(PORTNAME), win)
ifneq ($(SHLIB), $(SHLIB_MAJOR))
cd $(MODULE_INSTALLDIR) && \
rm -f $(SHLIB_MAHOR) && \
ln -sf $(SHLIB) $(SHLIB_MAJOR)
endif
ifneq ($(SHLIB), lib$(NAME)$(DLSUFFIX))
rm -f $(SHLIB_BARE) && \
ln -sf $(SHLIB) $(SHLIB_BARE)
endif
endif # not win
uninstall-lib:
rm -f $(MODULE_INSTALLDIR)/$(SHLIB)
rm -f $(MODULE_INSTALLDIR)/$(SHLIB_MAJOR)
rm -f $(MODULE_INSTALLDIR)/$(SHLIB_BARE)
detect_geos_version:
sh ../geos_version.sh $(GEOS_DIR) > postgis_geos_version.h
uninstall-lwgeom-scripts:
rm -f $(datadir)/postgis/lwpostgis.sql
rm -f $(datadir)/postgis/spatial_ref_sys.sql
uninstall: uninstall-lib uninstall-lwgeom-scripts
clean-lib:
rm -f $(SHLIB) $(SHLIB_MAJOR) $(SHLIB_BARE)
clean distclean: clean-lib
rm -f *.o *.so *.a test $(OTHERS)
maintainer-clean: clean
rm -f lex.yy.c wktparse.tab.c wktparse.tab.h
liblwgeom_sa.o: liblwgeom.c
$(CC) -DSTANDALONE -o $@ -c $<
liblwgeom_sa.so: $(SA_OBJS) liblwgeom_sa.o
$(CC) -shared -o $@ $^
liblwgeom_sa.a: $(SA_OBJS) liblwgeom_sa.o
$(AR) -rc $@ $^
test: liblwgeom_sa.so liblwgeom_sa.a test.c
$(CC) -Wall -lm -g -o test test.c liblwgeom_sa.a
tsort:
lorder $(SA_OBJS) | tsort
========================================[ postgis/loader/Makefile ] ===============================================================
# PostGIS Loader Makefile
SHELL = /bin/sh
subdir = contrib/postgis/loader
EXE =
UNAME = $(shell uname)
ifeq ($(findstring CYGWIN,$(UNAME)),CYGWIN)
EXE = .exe
endif
ifeq ($(findstring MINGW,$(UNAME)),MINGW)
EXE = .exe
endif
OBJS = shpopen.o dbfopen.o getopt.o
ifeq ($(USE_ICONV),1)
override CFLAGS += -DUSE_ICONV
endif
override CFLAGS := -g -Wall -I.. $(CFLAGS) -DUSE_VERSION=$(USE_VERSION)
all: shp2pgsql$(EXE) pgsql2shp$(EXE)
pgsql2shp.o: pgsql2shp.c
$(CC) $(CFLAGS) $(PGFEINCLUDES) -c $<
pgsql2shp$(EXE): $(OBJS) pgsql2shp.o PQunescapeBytea.o
$(CC) $(CFLAGS) $(OBJS) PQunescapeBytea.o pgsql2shp.o $(LDFLAGS) $(shell pg_config --libdir)/libpq.a -o $@
else
$(CC) $(CFLAGS) $(PGFELIBS) $(OBJS) PQunescapeBytea.o pgsql2shp.o $(LDFLAGS) -o $@
endif
shp2pgsql$(EXE): $(OBJS) shp2pgsql.o
$(CC) $(CFLAGS) $(OBJS) shp2pgsql.o $(LDFLAGS) -o $@
install: all
@mkdir -p $(bindir)
$(INSTALL_BIN) pgsql2shp$(EXE) $(bindir)/pgsql2shp$(EXE)
$(INSTALL_BIN) shp2pgsql$(EXE) $(bindir)/shp2pgsql$(EXE)
uninstall:
rm -f $(bindir)/pgsql2shp$(EXE)
rm -f $(bindir)/shp2pgsql$(EXE)
clean:
rm -f $(OBJS) shp2pgsql.o pgsql2shp.o shp2pgsql$(EXE) pgsql2shp$(EXE)
TECHER Jean David
01MAP
e-mail: david at 01map.net
Tél: 04 67 45 60 27
Entreprise: http://www.01map.net
Perso: http://techer.pascal.free.fr/postgis/
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050424/a97961cf/attachment.html>
