[postgis-users] Patch for building PostGIS on Windows from CVS
Jean David TECHER
davidtecher at yahoo.fr
Tue Apr 26 02:11:41 PDT 2005
Hi Sandro,
configure -with-geos.....works..OK!!
U're right..it is not worth typing 'which geos'...sorry...
Before building postgis it's better to update the PATH environment variable
by adding at the beginning of PATH
C:\PostgreSQL\8.0.2\bin;C:\PostgreSQL\8.0.2\lib;C:\PostgreSQL\8.0.2\lib\post
gresql
Should replae "C:\PostgreSQL\8.0.2" by the path to your PostgreSQL's
prefix...
My patch is attached to this mail (postgis_cvs.patch)...In order to applyng
it (thanks to Gerald for patching :-))
(I know that U know how to do...:-) )
copy the patch in the same directory of postgis directory:
/postgis
/postgis_cvs.patch
patch -p0 < postgis_cvs.patch
In my last mail I did a little mistake for Makefile;config.in...sorry
PGCONFIG=@PGCONFIG@
PGFEINCLUDES=@PGFEINCLUDES@
+ifeq ($(findstring MINGW,$(MSYSTEM)),MINGW)
+PGBEINCLUDES=@PGBEINCLUDES@ @PGBEINCLUDES@/port @PGBEINCLUDES@/port/win32
@PGBEINCLUDES@/port/win32/arpa
+PGFELIBS=$(shell @PGCONFIG@ --libdir)
+else
PGFELIBS=@PGFELIBS@
NOTICE: BUILDING POSTGIS DOCUMENTATION
The last thing to do - for people who wants to compil postgis on windows -
is to take care of Docbook, iconv.dll and xsltproc
Else 'make install' wil stop for "make -C doc"
The best link I know for that is http://xmlsoft.org/sources/win32 They have
to download:
- iconv-1.9.1.win32.zip ( contains icon.exe and iconv.dll)
- libxml2-2.6 18.win32.zip
- libxslt-1.1.13.win32.zip (contains xsltproc.exe)
and install it to MinGW repository (C:\MinGW)
For DocBook XSL files, they have to download from
http://sourceforge.net/projects/docbook (find docbook-xsl version 1.68.1
or
http://prdownloads.sourceforge.net/docbook/docbook-xsl-1.68.1.zip?download
then to create the DOS path C:\msys\1.0\share\sgml\docbook\xsl-stylesheets
(or GNU/Linux PATH /usr/share/sgml/docbook/xsl-stylesheets)
and finally copy the contents of docbook-xsl-1.68.1.zip ( commons, fo, ...)
in this directory C:\msys\1.0\share\sgml\docbook\xsl-stylesheets
For people who wants to build postgis.pdf ( postgis.fo ----------->
postgis.pdf ), I pupose to use (FOP from java) or install MikTeX (= laTeX
distribution) for windows that contains pdfxmltex.exe
Here is the contense of the patch:
--- postgis/Makefile.config.in Tue Apr 19 10:41:21 2005
+++ postgis/Makefile.config.in Mon Apr 25 12:43:59 2005
@@ -71,9 +71,13 @@
PGCONFIG=@PGCONFIG@
+else
PGFELIBS=@PGFELIBS@
+endif
# Docbook
@@ -112,8 +116,13 @@
# DLL
-DLSUFFIX=@DLSUFFIX@
-DLFLAGS=@DLFLAGS@
+ DLSUFFIX=.dll
+ DLFLAGS=@DLFLAGS@
+else
+ DLSUFFIX=@DLSUFFIX@
+ DLFLAGS=@DLFLAGS@
+endif
# END OF CONFIGURATION
--- postgis/loader/Makefile Mon Apr 18 14:46:48 2005
+++ postgis/loader/Makefile Mon Apr 25 12:40:44 2005
@@ -32,7 +32,13 @@
$(CC) $(CFLAGS) $(PGFEINCLUDES) -c $<
pgsql2shp$(EXE): $(OBJS) pgsql2shp.o PQunescapeBytea.o
+ $(CC) $(CFLAGS) $(OBJS) PQunescapeBytea.o pgsql2shp.o $(LDFLAGS)
$(PGFELIBS)/libpq.a -o $@
+else
$(CC) $(CFLAGS) $(PGFELIBS) $(OBJS) PQunescapeBytea.o pgsql2shp.o
$(LDFLAGS) -o $@
+endif
shp2pgsql$(EXE): $(OBJS) shp2pgsql.o
$(CC) $(CFLAGS) $(OBJS) shp2pgsql.o $(LDFLAGS) -o $@
--- postgis/lwgeom/Makefile Wed Apr 20 15:17:37 2005
+++ postgis/lwgeom/Makefile Mon Apr 25 12:09:17 2005
@@ -13,21 +13,32 @@
# Shared library parameters.
NAME=lwgeom
+SHLIB =
lib$(NAME).$(SO_MAJOR_VERSION).$(SO_MINOR_VERSION)$(DLSUFFIX)
+SHLIB_MAJOR = lib$(NAME)$(DLSUFFIX).$(SO_MAJOR_VERSION)
+SHLIB_BARE = lib$(NAME)$(DLSUFFIX)
+SHLIB_LINK =
+else
SHLIB =
lib$(NAME)$(DLSUFFIX).$(SO_MAJOR_VERSION).$(SO_MINOR_VERSION)
-SHLIB_LINK = $(DLFLAGS)
+SHLIB_LINK = $(DLFLAGS)
+endif
MODULE_FILENAME = $(LPATH)/$(SHLIB)
# Postgis version and build date
-POSTGIS_VERSION = $(SO_MAJOR_VERSION).$(SO_MINOR_VERSION)
USE_GEOS=$(USE_GEOS) USE_PROJ=$(USE_PROJ) USE_STATS=$(USE_STATS)
-POSTGIS_LIB_VERSION =
$(SO_MAJOR_VERSION).$(SO_MINOR_VERSION).$(SO_MICRO_VERSION)
-POSTGIS_BUILD_DATE := $(shell date -u "+%Y-%m-%d %H:%M:%S")
+ POSTGIS_VERSION = $(SO_MAJOR_VERSION).$(SO_MINOR_VERSION)
+ POSTGIS_LIB_VERSION =
+ POSTGIS_BUILD_DATE := $(shell date -u "+%Y-%m-%d %H:%M:%S")
+else
+endif
@@ -87,8 +98,17 @@
all: $(GEOS_RULES) $(SHLIB) ../lwpostgis.sql
+#------------ It's for Win32 -----------------------------------
$(SHLIB): $(OBJS)
+ dlltool --export-all --output-def lwgeom.def $(OBJS)
+ dllwrap -o $@ --dllname $@ --def lwgeom.def $(OBJS)
$(SHLIB_LINK) -L$(shell pg_config --libdir) -lpostgres
+ dlltool --dllname $@ --def lwgeom.def --output-lib liblwgeom.a
+else
$(CC) $(SHLIB_LINK) -o $(SHLIB) $(OBJS)
+endif
wktparse.tab.c: wktparse.y
$(YACC) -vd -p lwg_parse_yy wktparse.y
TECHER Jean David
01MAP
e-mail: david at 01map.net
Tél: 04 67 45 60 27
Entreprise: http://www.01map.net
Perso: http://techer.pascal.free.fr/postgis/
----- Original Message -----
To: "Jean David TECHER" <davidtecher at yahoo.fr>
Cc: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
Sent: Monday, April 25, 2005 1:44 AM
Subject: Re: [postgis-users] Building PostGIS from Sunday CVS..without
PostgreSQL Sources...OK ! ! !
> On Sun, Apr 24, 2005 at 07:39:38PM +0200, Jean David TECHER wrote:
> > Hi Sandro and PostGIS'ers,
> > Last Sunday, I decided to compil PostGIS from CVS (form sunday in the
afternoon)...
> > Since the goal is to build PostGIS WITHOUT PostgreSQL sources but from
the binairies installed on the computer
> > the tests on Windows for me is OK...Successfull...I did it for PG 8.0.2,
Geos 2.1.1 and Proj 4.4.9
> Good news!
> Weird I didn't change anything since your worried mails ;)
> > The only changes -I had to do - were to make few changes on:
> > -1/ postgis/Makefile.config.in
> > - 2/postgis/lwgeom/Makefile
> > - 3/postgis/loader/Makefile
> > For each file, I used
> > XXXXXXXXX
> > else
> > XXXXXXXXXX
> > endif
> I'd put the XXXXXX all in Makefile.config.in.
> > The changes in files are at the end of this files (sorry, I didn't at
enough times to make patch... :-[ ....)
> > Since i'm not at job on Monday but Tuesday, I will do a resume doc next
Tuesday
> > NOTICE: For creating postgis doc, I need to have
docbook-xslt-stylesheets, xlstproc and icon.dll installed on
Windows..Nevermind
> > Just 3 downloading to do.
> > cvs -d:pserver:cvs at postgis.refractions.net:/home/cvs/postgis login
> > cvs -d:pserver:cvs at postgis.refractions.net:/home/cvs/postgis co postgis
> > cd postgis
> > autoconf
> > configure --enable-autotconf --with-geos=`which geos-config`
> If geos-config is in your PATH, which is what you expect using which,
there should be
> no need to be explicit. A simple --with-geos should work.
> > make
> > make install
> > cd regress
> > make
> > Regression Tests, Loading some data with the laoder (...) work fine...
> Thanks! See you on Tuesday with patches then :)
> --strk;
========================================[postgis/Makefile.config.in ]=======
> > # Configuration Directives
> > # We recommend that you install the Proj4 and GEOS libraries
> > # referenced below to get the most use out of your PostGIS
> > # database.
> > # Set USE_PROJ to 1 for Proj4 reprojection support (recommended)
> > # Reprojection allows you to transform coordinate systems
> > # in the database with the Transform() function.
> > # Download from: http://www.remotesensing.org/proj
> > USE_PROJ=@USE_PROJ@
> > PROJ_DIR=@PROJ_DIR@
> > # Set USE_GEOS to 1 for GEOS spatial predicate and operator
> > # support (recommended).
> > # GEOS installation directory defaults to /usr/local,
> > # set GEOS_DIR environment variable to change it.
> > # GEOS allows you to do exact topological tests, such as
> > # Intersects() and Touches(), as well as geometry operations,
> > # such as Buffer(), GeomUnion() and Difference().
> > # Download from: http://geos.refractions.net
> > USE_GEOS=@USE_GEOS@
> > GEOS_DIR=@GEOS_DIR@
> > # Set USE_JTS to 1 if you have libjts installed.
> > USE_JTS=0
> > JTS_INCLUDES=@JTS_INCLUDES@
> > JTS_LIBDIR=@JTS_LIBDIR@
> > # Set USE_STATS to 1 for new GiST statistics collection support
> > # Note that this support requires additional columns in
> > # GEOMETRY_COLUMNS, so see the list archives for info or
> > # install a fresh database using postgis.sql.
> > # This option is useless for builds against PGSQL>=80 (stats
> > # are always gathered in that case, and you don't need additional
> > # columns in geometry_columns).
> > USE_STATS=1
> > # Set AUTOCACHE_BBOX to 0 if you want finer control over
> > # bounding box computation and caching for your geometries.
> > # If you do, bbox computattion strategies are listed in
> > # the file lwgeom/BBOXCACHE_BEHAVIOURS, but don't expect
> > # them to be easy nor consistent.
> > AUTOCACHE_BBOX=1
> > # Set USE_ICONV to 1 if you want the loader (shp2pgsql)
> > # to support UTF-8 output.
> > USE_ICONV=0
> > # PGSQL
> > PGCONFIG=@PGCONFIG@
@PGBEINCLUDES@/port/win32 @PGBEINCLUDES@/port/win32/arpa
> > else
> > PGFELIBS=@PGFELIBS@
> > endif
> > # Docbook
> > XSLBASE=@XSLBASE@
> > # Compilers
> > CC=@CC@
> > CXX=@CXX@
> > # Other programs
> > FLEX=@FLEX@
> > YACC=@YACC@
> > INSTALL=@INSTALL@ -c
> > INSTALL_DATA=$(INSTALL) -m 644
> > INSTALL_BIN=$(INSTALL) -m 755
> > INSTALL_LIB=$(INSTALL) -m 755
> > # PATHS
> > prefix=@prefix@
> > exec_prefix=@exec_prefix@
> > bindir=@bindir@
> > datadir=@datadir@
> > mandir=@mandir@
> > docdir=@docdir@
> > libdir=@libdir@
> > libexecdir=@libexecdir@
> > MODULE_INSTALLDIR=@MODULE_INSTALLDIR@
> > LPATH=@LPATH@
> > # DLL
> > DLSUFFIX=.dll
> > DLFLAGS=@DLFLAGS@
> > else
> > DLSUFFIX=@DLSUFFIX@
> > DLFLAGS=@DLFLAGS@
> > endif
> > # Use JTS instead of GEOS if available
> > ifeq ($(USE_JTS),1)
> > USE_GEOS=0
> > endif
> > # Test the version string and set the USE_VERSION macro
> > # appropriately.
> > VERSION=$(shell $(PGCONFIG) --version)
> > ifneq ($(findstring 7.1,$(VERSION)),)
> > USE_VERSION=71
> > else
> > ifneq ($(findstring 7.2,$(VERSION)),)
> > USE_VERSION=72
> > else
> > ifneq ($(findstring 7.3,$(VERSION)),)
> > USE_VERSION=73
> > else
> > ifneq ($(findstring 7.4,$(VERSION)),)
> > USE_VERSION=74
> > else
> > USE_VERSION=80
> > endif
> > endif
> > endif
> > endif
postgis/lwgeom/Makefile ]===================================================
> > include ../Makefile.config
> > include ../Version.config
> > # Default missing CXX variable to c++
> > ifeq ($(CXX),)
> > CXX = c++
> > endif
> > NAME=lwgeom
> > SHLIB =
> > SHLIB_LINK =
> > else
> > SHLIB =
> > endif
> > else
> > endif
> > override CFLAGS += -g -O2 -fexceptions
> > override CFLAGS += -fPIC
> > #override CFLAGS
+= -I$(srcdir) -DFRONTEND -DSYSCONFDIR='"$(sysconfdir)"'
> > override CFLAGS += -DUSE_VERSION=$(USE_VERSION)
> > override CFLAGS += -DPOSTGIS_LIB_VERSION='"$(POSTGIS_LIB_VERSION)"'
> > override CFLAGS += -DPOSTGIS_SCRIPTS_VERSION='"$(SCRIPTS_VERSION)"'
> > override CFLAGS += -DPOSTGIS_BUILD_DATE='"$(POSTGIS_BUILD_DATE)"'
> > JTS_OBJ=lwgeom_nojts.o
> > ifeq ($(USE_GEOS),1)
> > override CFLAGS += -I$(GEOS_DIR)/include -DUSE_GEOS
> > GEOS_RULES=detect_geos_version
> > GEOS_WRAPPER=lwgeom_geos_wrapper.o
> > JTS_OBJ=lwgeom_geos.o
> > SHLIB_LINK += -lstdc++ -L$(GEOS_DIR)/lib -lgeos
> > endif
> > ifeq ($(USE_JTS),1)
> > override CFLAGS += -I$(JTS_INCLUDES) -DUSE_JTS
> > JTS_WRAPPER=lwgeom_jts_wrapper.o
> > JTS_OBJ=lwgeom_jts.o
> > SHLIB_LINK += -lgcj -ljts -lstdc++ -L$(JTS_LIBDIR)
> > endif
> > ifeq ($(USE_PROJ),1)
> > override CFLAGS += -I$(PROJ_DIR)/include -DUSE_PROJ
> > SHLIB_LINK += -L$(PROJ_DIR)/lib -lproj
> > endif
> > override CFLAGS += $(PGBEINCLUDES) -DAUTOCACHE_BBOX=$(AUTOCACHE_BBOX)
> > override CXXFLAGS := $(CFLAGS)
> > # memory debug for gcc 2.91, 2.95, 3.0 and 3.1
> > # for gcc >= 3.2.2 set GLIBCPP_FORCE_NEW at runtime instead
> > #override CXXFLAGS += -D__USE_MALLOC
> > # Add index selectivity to C flags
> > ifeq ($(USE_STATS),1)
> > override CFLAGS += -DUSE_STATS
> > endif
> > SA_OBJS=measures.o box2d.o ptarray.o lwgeom_api.o lwgeom.o lwpoint.o
lwline.o lwpoly.o lwmpoint.o lwmline.o lwmpoly.o lwcollection.o
$(GEOS_WRAPPER) $(JTS_WRAPPER) wktunparse.o lwgparse.o wktparse.tab.o
lex.yy.o vsprintf.o
> > OBJS=$(SA_OBJS) liblwgeom.o lwgeom_pg.o lwgeom_debug.o lwgeom_spheroid.o
lwgeom_ogc.o lwgeom_functions_analytic.o $(JTS_OBJ) lwgeom_inout.o
lwgeom_estimate.o lwgeom_functions_basic.o lwgeom_gist.o lwgeom_btree.o
lwgeom_transform.o stringBuffer.o lwgeom_box.o lwgeom_box3d.o
lwgeom_box2dfloat4.o lwgeom_chip.o lwgeom_svg.o lwgeom_gml.o
lwgeom_triggers.o lwgeom_dump.o
> > #OTHERS=y.output lex.yy.c wktparse.tab.c wktparse.tab.h lwpostgis.sql
> > OTHERS=y.output lwpostgis.sql ../lwpostgis.sql postgis_geos_version.h
> > # Makefile targets
> > $(SHLIB): $(OBJS)
> > else
> > endif
> > mv -f y.tab.c wktparse.tab.c
> > mv -f y.tab.h wktparse.tab.h
> > lex.yy.c: wktparse.lex wktparse.tab.c
> > $(FLEX) -Plwg_parse_yy -i -f -o'lex.yy.c' wktparse.lex
> > lwgeom_jts_wrapper.o: lwgeom_jts_wrapper.cpp
> > lwgeom_geos_wrapper.o: lwgeom_geos_wrapper.cpp
> > lwgeom_geos.o: lwgeom_geos.c profile.h
> > lwgeom_jts.o: lwgeom_jts.c profile.h
> > lwgeom_nojts.o: lwgeom_nojts.c
> > lwgeom_functions_basic.o: lwgeom_functions_basic.c profile.h
> > # Shared library stuff
> > ../lwpostgis.sql: lwpostgis.sql
> > cp lwpostgis.sql ..
> > lwpostgis.sql: lwpostgis.sql.in
> > cpp -P -traditional-cpp -DUSE_VERSION=$(USE_VERSION) $< | sed -e
's:@MODULE_FILENAME@:$(MODULE_FILENAME):g;s:@POSTGIS_VERSION@:$(POSTGIS_VERS
ION):g;s:@POSTGIS_SCRIPTS_VERSION@:$(SCRIPTS_VERSION):g;s/@POSTGIS_BUILD_DAT
E@/$(POSTGIS_BUILD_DATE)/g' | grep -v '^#' > $@
> > install: all install-lwgeom-lib install-lwgeom-scripts
> > install-lwgeom-scripts:
> > @mkdir -p $(datadir)
> > $(INSTALL_DATA) lwpostgis.sql $(datadir)/lwpostgis.sql
> > $(INSTALL_DATA) ../spatial_ref_sys.sql $(datadir)/spatial_ref_sys.sql
> > #- This has been copied from postgresql and adapted
> > install-lwgeom-lib: $(SHLIB)
> > @mkdir -p $(MODULE_INSTALLDIR)
> > $(INSTALL_LIB) $< $(MODULE_INSTALLDIR)/$(SHLIB)
> > ifneq ($(PORTNAME), win)
> > ifneq ($(SHLIB), $(SHLIB_MAJOR))
> > cd $(MODULE_INSTALLDIR) && \
> > rm -f $(SHLIB_MAHOR) && \
> > ln -sf $(SHLIB) $(SHLIB_MAJOR)
> > endif
> > ifneq ($(SHLIB), lib$(NAME)$(DLSUFFIX))
> > rm -f $(SHLIB_BARE) && \
> > ln -sf $(SHLIB) $(SHLIB_BARE)
> > endif
> > endif # not win
> > uninstall-lib:
> > rm -f $(MODULE_INSTALLDIR)/$(SHLIB)
> > rm -f $(MODULE_INSTALLDIR)/$(SHLIB_MAJOR)
> > rm -f $(MODULE_INSTALLDIR)/$(SHLIB_BARE)
> > detect_geos_version:
> > sh ../geos_version.sh $(GEOS_DIR) > postgis_geos_version.h
> > uninstall-lwgeom-scripts:
> > rm -f $(datadir)/postgis/lwpostgis.sql
> > rm -f $(datadir)/postgis/spatial_ref_sys.sql
> > uninstall: uninstall-lib uninstall-lwgeom-scripts
> > clean-lib:
> > rm -f $(SHLIB) $(SHLIB_MAJOR) $(SHLIB_BARE)
> > clean distclean: clean-lib
> > rm -f *.o *.so *.a test $(OTHERS)
> > maintainer-clean: clean
> > rm -f lex.yy.c wktparse.tab.c wktparse.tab.h
> > liblwgeom_sa.o: liblwgeom.c
> > $(CC) -DSTANDALONE -o $@ -c $<
> > liblwgeom_sa.so: $(SA_OBJS) liblwgeom_sa.o
> > $(CC) -shared -o $@ $^
> > liblwgeom_sa.a: $(SA_OBJS) liblwgeom_sa.o
> > $(AR) -rc $@ $^
> > test: liblwgeom_sa.so liblwgeom_sa.a test.c
> > $(CC) -Wall -lm -g -o test test.c liblwgeom_sa.a
> > tsort:
> > lorder $(SA_OBJS) | tsort
> > ========================================[ postgis/loader/Makefile ]
> > # PostGIS Loader Makefile
> > SHELL = /bin/sh
> > subdir = contrib/postgis/loader
> > EXE =
> > UNAME = $(shell uname)
> > ifeq ($(findstring CYGWIN,$(UNAME)),CYGWIN)
> > EXE = .exe
> > endif
> > ifeq ($(findstring MINGW,$(UNAME)),MINGW)
> > EXE = .exe
> > endif
> > OBJS = shpopen.o dbfopen.o getopt.o
> > ifeq ($(USE_ICONV),1)
> > override CFLAGS += -DUSE_ICONV
> > endif
> > override CFLAGS := -g -Wall -I.. $(CFLAGS) -DUSE_VERSION=$(USE_VERSION)
> > all: shp2pgsql$(EXE) pgsql2shp$(EXE)
> > pgsql2shp.o: pgsql2shp.c
$(shell pg_config --libdir)/libpq.a -o $@
> > else
$(LDFLAGS) -o $@
> > endif
> > install: all
> > @mkdir -p $(bindir)
> > $(INSTALL_BIN) pgsql2shp$(EXE) $(bindir)/pgsql2shp$(EXE)
> > $(INSTALL_BIN) shp2pgsql$(EXE) $(bindir)/shp2pgsql$(EXE)
> > uninstall:
> > rm -f $(bindir)/pgsql2shp$(EXE)
> > rm -f $(bindir)/shp2pgsql$(EXE)
> > clean:
> > rm -f $(OBJS) shp2pgsql.o pgsql2shp.o shp2pgsql$(EXE) pgsql2shp$(EXE)
> > TECHER Jean David
> > 01MAP
> > Tél: 04 67 45 60 27
> > postgis-users mailing list
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
TECHER Jean David
01MAP
Tél: 04 67 45 60 27
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050426/4a8c05d5/attachment.html>
