[postgis-users] valid MULTIPOLYGONs and order of vertices?
strk at refractions.net strk at refractions.net
Tue Apr 26 11:40:45 PDT 2005
On Tue, Apr 26, 2005 at 04:01:51PM +0200, Hubert Fröhlich wrote:
> strk at refractions.net schrieb:
> >>So, the dilemma of the quasi-standard
> >>* A correct Shape is what is defined by the specs (or is it just  a
> >>white paper?)
> >>vs.
> >>* A correct Shape is (more or less) what can be treated by ESRI
> >>software without errors
> >>will remain forever...
> >We actually don't care about being standard, if not because it allows
> >ease of interoperability. For this specific case what matters is that
> >pgsql2shp produces "working" shapefiles. A solution could be
> >implementing a stored procedure for specifically this kind of cleanup:
> >makeShapeValid(geometry). This would allow us to initially just
> >implement duplicated vertex removal, and incrementally add any new
> >"discovered" pickiness of Shapefile format.
> >What people think about this ?
> >--strk;
> Good idea!!!
Item added in the growing TODO list in head branch.
--strk;
> Mit freundlichen Grüßen / With kind regards
> Hubert Fröhlich
> Dr.-Ing. Hubert Fröhlich
> Bezirksfinanzdirektion München
> Alexandrastr. 3, D-80538 München, GERMANY
> Tel. :+49 (0)89 / 2190 - 2980
> Fax  :+49 (0)89 / 2190 - 2997
> hubert dot froehlich at bvv dot bayern dot de
> postgis-users mailing list
