[postgis-users] Convert X/Y into geometry
    Jeffrey Johnson
    ortelius at gmail.com
    Wed Apr 27 14:52:47 PDT 2005
I assume you mean like this
update localities set localities_geom=SetSRID(MakePoint(UTM_NORTHING,
UTM_EASTING), 26711);
Where localities_geom is the point geometry field and 26711 is the
SRID (NAD27 UTMZ11N)
Seems to work, I'll see what mapserver has to say.
Thanks,
Jeff
On 4/27/05, strk at refractions.net <strk at refractions.net> wrote:
> On Wed, Apr 27, 2005 at 02:03:15PM -0700, Jeffrey Johnson wrote:
> > Hi all,
> > What is the easiest/quickest way to convert a set of x,y points in an
> > existing table into geometry for PostGIS. I have a table LOCALITIES
> > with UTM_NORTHING and UTM_EASTING fields, and I want to prepare this
> > table for display via mapserver. Not sure how to go about doind this.
> SetSRID(MakePoint(UTM_NORTHING, UTM_EASTING), <SRID>) from LOCALITIES;
> --strk;
> > Thanks in advance,
> > Jeff
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
