[postgis-users] Making shp2pgsql using iconv in /usr/local?
strk at refractions.net strk at refractions.net
Thu Dec 1 01:31:18 PST 2005
On Wed, Nov 30, 2005 at 10:01:39PM -0500, Mike Leahy wrote:
> Hello again,
> On second thought, a cleaner solution to this is to add "#define
> LIBICONV_PLUG" just before the line with "#include <iconv.h>" in
> shp2pgsql.c.  This essentially accomplishes the same (i.e., avoids
> redefinition of the libiconv_* functions), and without hacking-up the
> iconv.h like I did in my previous.  I tried to do this via the make
> command like so:
>  CFLAGS="-DLIBICONV_PLUG" make
> as well as
>  CFLAGS="-DLIBICONV_PLUG" make loaderdumper
> but that had no effect (is this right the right way?).  I think part of
> the issue here is that CFLAGS is reset at the start of loader/Makefile,
> so any CFLAGS (or LDFLAGS) options that are supplied when executing make
> are wiped by the time the loader source is compiled.
Setting CFLAGS in the environment works fine with postgis-head.
The CFLAGS reset happens in PGSQL_SRC/Makefile.global, there's
no easy fix for 1.0.
> Should LIBICONV_PLUG be an option that is just always enabled when
> USE_ICONV=1, or should it be optional?  Everything worked fine when I
> added "LIBICONV_PLUG = 1" in Makefile.config, then the following lines
> in loader/Makefile:
> ifeq ($(LIBICONV_PLUG),1)
> 	override CFLAGS += -DLIBICONV_PLUG
> endif
I guess that LIBICONV_PLUG forces you to use the glibc version
rather then libiconv, right ? This would fail on system with
libiconv *only* external to libc, correct ?
Mapserver solution was to always link against libiconv if present and let
header file inclusion determine which version to use.
I've committed a patch for the 1.0 branch allowing you to specify
ICONV_LDFLAGS and ICONV_CFLAGS, please check if that would do for
you. Your choice would be:
	ICONV_CFLAGS="-DLIBICONV_PLUG" make
Original user choice would be something like:
	ICONV_CFLAGS="-I/usr/local/include" \
		ICONV_LDFLAGS="-L/usr/local/lib -liconv" make
Let me know if this makes it.
I'd reserve changes in the HEAD branch for later, to allow for
autodetection of cases in which external lib only supports iconv.
Filing a bug report would help keeping track of this.
Thanks.
--strk;
> Anyway, that's all for now.
> Regards,
> Mike
> Mike Leahy wrote:
> >Hey there,
> >I think this problem might be related to a bug found with MapServer a
> >while back: http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=909
> >I tried commenting out the following lines in /usr/local/include/iconv.h
> >(version 1.10), and PostGIS compiled without errors:
> >45: //#undef iconv_t
> >46: //#define iconv_t libiconv_t
> >70: //#define iconv_open libiconv_open
> >80: //#define iconv libiconv
> >86: //#define iconv_close libiconv_close
> >96: //#define iconvctl libiconvctl
> >119: //#define iconvlist libiconvlist
> >I have no idea if this breaks anything...I just figured it was related
> >to conflicting libraries as suggested in the MapServer bug referenced
> >above.
> >I'm running FC4, with the most recent upgrades.
> >I hope this helps.
> >Mike
> >Larry Shaffer wrote:
> >>strk,
> >>Sorry for the lack of info on my part. I'd like to get this working, but
> >>it's no big thing until I get ready to install the upcoming PostGIS 1.0.6
> >>version, as this is a brand new setup (PostgreSQL and all) with no real
> >>data installed into yet.
> >>Make for PostGIS works fine with USE_ICONV ?= 0
> >>My src path is /usr/local/src/postgresql-8.1.0/contrib/postgis
> >>These are the values in the PGISSRC/Makefile.config:
> >>USE_PROJ ?= 1
> >>PROJ_DIR ?= /usr/local
> >>USE_GEOS ?= 1
> >>GEOS_DIR ?= /usr/local
> >>USE_JTS ?= 0
> >>JTS_INCLUDES = /usr/local/include
> >>JTS_LIBDIR = /usr/local/lib
> >>USE_STATS=1
> >>AUTOCACHE_BBOX ?= 1
> >>PGSQL_SRC=/usr/local/src/postgresql-8.1.0
> >>USE_ICONV ?= 1
> >>(set to 0 for PostGIS make, then to 1 for shp2pgsql make)
> >>LPATH=/usr/local/src/postgresql-8.1.0/contrib/postgis
> >>What's in /usr/local/lib
> >>libiconv_plug.so
> >>libiconv.la
> >>libiconv.so
> >>libiconv.so.2
> >>libiconv.so.2.2.0
> >>What's in /usr/local/include
> >>iconv.h
> >>and whereis?
> >>sh-2.05a# whereis libiconv
> >>libiconv: /usr/local/lib/libiconv.so /usr/local/lib/libiconv.la
> >>sh-2.05a# whereis iconv
> >>iconv: /usr/bin/iconv /usr/local/bin/iconv /usr/include/iconv.h /usr/
> >>share/man/man1/iconv.1.gz /usr/share/man/man3/iconv.3.gz
> >>(Where is /usr/local/include/iconv.h? It *does* exist in /usr/local/
> >>include. This could be the problem...)
> >>Running  iconv -l  for /usr and /usr/local provides positive results of
> >>listing encodings (i.e. both are working).
> >>sh-2.05a# /usr/bin/iconv --version
> >>iconv (GNU libc) 2.2.5
> >>Copyright (C) 2002 Free Software Foundation, Inc.
> >>Written by Ulrich Drepper.
> >>sh-2.05a# /usr/local/bin/iconv --version
> >>iconv (GNU libiconv 1.9)
> >>Copyright (C) 2000-2002 Free Software Foundation, Inc.
> >>Written by Bruno Haible.
> >>I installed the libiconv-1.9.1 from GNU since it was a standalone.
> >>Should I install the Standard C library (glibc-2.3.2) in /usr/local ? I
> >>don't think the /usr/local extras before make command of shp2pgsql are
> >>making a difference, so I don't think it's worth the effort right now.
> >>See the following...
> >>Here's the output from the /usr/local extras
> >>(run from within contrib/postgis/loader)
> >>sh-2.05a# LDFLAGS="-L/usr/local/lib -liconv" CFLAGS="-I/usr/local/
> >>include" make shp2pgsql
> >>make: `shp2pgsql' is up to date.
> >>sh-2.05a# make clean
> >>rm -f shpopen.o dbfopen.o getopt.o PQunescapeBytea.o shp2pgsql.o
> >>pgsql2shp.o shp2pgsql pgsql2shp
> >>gcc -g -Wall -I.. -I. -I/usr/local/src/postgresql-8.1.0/src/interfaces/
> >>libpq -O2 -Wall -Wmissing-prototypes -Wpointer-arith -Winline -fno-
> >>strict-aliasing -DUSE_ICONV -DFRONTEND -DSYSCONFDIR='"/usr/local/pgsql/
> >>etc"' -DUSE_VERSION=81 -I/usr/local/src/postgresql-8.1.0/src/include -
> >>D_GNU_SOURCE  -I/usr/local  -c -o shpopen.o shpopen.c
> >>shpopen.c:176: warning: `rcsid' defined but not used
> >>D_GNU_SOURCE  -I/usr/local  -c -o dbfopen.o dbfopen.c
> >>dbfopen.c:200: warning: `rcsid' defined but not used
> >>D_GNU_SOURCE  -I/usr/local  -c -o getopt.o getopt.c
> >>D_GNU_SOURCE  -I/usr/local  -c -o PQunescapeBytea.o PQunescapeBytea.c
> >>D_GNU_SOURCE  -I/usr/local  -c -o shp2pgsql.o shp2pgsql.c
> >>etc"' -DUSE_VERSION=81 shpopen.o dbfopen.o getopt.o PQunescapeBytea.o
> >>shp2pgsql.o -L/usr/local/src/postgresql-8.1.0/src/port -lstdc++  -L/usr/
> >>local -Wl,-rpath,/usr/local/pgsql/lib -o shp2pgsql shp2pgsql.o: In
> >>function `utf8':
> >>/usr/local/src/postgresql-8.1.0/contrib/postgis/loader/shp2pgsql.c:1630:
> >>undefined reference to `libiconv_open'
> >>/usr/local/src/postgresql-8.1.0/contrib/postgis/loader/shp2pgsql.c:1648:
> >>undefined reference to `libiconv'
> >>/usr/local/src/postgresql-8.1.0/contrib/postgis/loader/shp2pgsql.c:1654:
> >>undefined reference to `libiconv_close'
> >>collect2: ld returned 1 exit status
> >>make: *** [shp2pgsql] Error 1
> >>and without the /usr/local extras... just 'make shp2pgsql'...
> >>exactly the same results.
> >>I don't think /usr/local/include/incov.h is being located. Either way,
> >>it's failing to make when using the base install of Debian
> >>[linus]$ uname -a
> >>Linux linus 2.4.28-grsec+w+fhs6b+gr0501+nfs+++p4+c4+gr6b-v6.188 #1 SMP
> >>Fri Jan 14 11:41:59 PST 2005 i686 unknown
> >>Any help would be appreciated. Thanx.
> >_______________________________________________
> >postgis-users mailing list
> >postgis-users at postgis.refractions.net
> >http://postgis.refractions.net/mailman/listinfo/postgis-users
 /"\    ASCII Ribbon Campaign
 \ /    Respect for open standards
  X     No HTML/RTF in email
 / \    No M$ Word docs in email
