[postgis-users] Making shp2pgsql using iconv in /usr/local?
Larry Shaffer larry at shafferinteractive.com
Thu Dec 1 08:18:49 PST 2005
strk and Mike,
Thanx for all your help. Problem is solved! No special make FLAGS needed.
After checking into <http://mapserver.gis.umn.edu/bugs/show_bug.cgi?
id=909> as noted by Mike, it got me to thinking... What do you do when
two 'similar' libraries are not playing nice when installed in normal
directories of your PATH? Un-install, then re-install the lesser of the
two into a non-standard location. Viola! I re-installed the standalone
libiconv-1.9.1 into /usr/local/my_iconv/ instead of the default /usr/
local and that did the trick. I was then able to make PostGIS's loader
using the /usr iconv with only 'make' as the command (with USE_ICONV ?=
1) and it worked as advertised. Also, I was able to compile other
installs that were having the same problem caused by finding/referencing
multiple installs of iconv (somehow), ala ./configure errors:
undefined reference to `libiconv_open'
undefined reference to `libiconv'
undefined reference to `libiconv_close'
Why do I need the two iconv installs? Well, I'm installing at the /usr/
local level for all users on my managed server, with the /usr level
installs managed by my provider. I could have used the /usr install of
iconv for everything, if that would have worked. It didn't. It worked
for libxml2, fontconfig, and PostGIS, but NOT for PHP. PHP said I had to
reinstall /usr/iconv. ?Huh?
Needless to say, I had to re-compile a bunch of installs that used the /
usr/local iconv. :(
So, I just installed the standalone libiconv-1.9.1 into a non-standard
directory and referenced it in the ./configure of software that seemed
to need it, while I left alone installs that could cope with the /usr
iconv if they were not 'cross-linked' into something down the road, like
PHP (had this problem with libxml2 if libxml2 used the /usr iconv) or
Mapserver.
Again, thanx for the help. Everything, including PHP, and Mapserver now
work, though I haven't tested localization support. I have not had time
to test PostGIS (or its loader), just install it and import its SQL into
a PostgreSQL db.
To sum up: Installing the standalone libiconv-1.9.1 into /usr/local if
you already have iconv installed under /usr is not a good idea (at least
on my server), seemingly regardless of whether you can specify --with-
iconv=/usr/local while installing.
>In the absence of glibc ICONV_LDFLAGS would also be needed.
>Larry, can you check you can have your requirements met with the
>version in pgis_1_0 CVS ? You can set ICONV_LDFLAGS and ICONV_CFLAGS
>in Makefile.config as well (no need to use environment).
I don't think I know enough about such things to really help debug that.
I can try if you need.
Larry
# strk at refractions.net (strk at refractions.net) emailed the following on
#   Thu, Dec 1, 2005 at 12:34 PM (4:34 AM South Dakota)
>On Thu, Dec 01, 2005 at 06:29:27AM -0500, Mike Leahy wrote:
>> Good morning.
>> cvs branch 'pgis_1_0' compiled fine for me using the flags as you
indicated:
>>   ICONV_CFLAGS="-DLIBICONV_PLUG" make
>> I figure you're right about LIBICONV_PLUG forcing the use of glibc
>> instead of libiconv.  If it is defined, the lines that look like
>>   "#define iconv* libiconv*"
>> are all skipped in iconv.h, and shp2pgsql compiles nicely.  Presumably
>> those define statements would be needed in the absence of glibc.
>--strk;
>> Mike
>> strk at refractions.net wrote:
>> >On Wed, Nov 30, 2005 at 10:01:39PM -0500, Mike Leahy wrote:
>> >>Hello again,
>> >>On second thought, a cleaner solution to this is to add "#define
>> >>LIBICONV_PLUG" just before the line with "#include <iconv.h>" in
>> >>shp2pgsql.c.  This essentially accomplishes the same (i.e., avoids
>> >>redefinition of the libiconv_* functions), and without hacking-up the
>> >>iconv.h like I did in my previous.  I tried to do this via the make
>> >>command like so:
>> >>as well as
>> >> CFLAGS="-DLIBICONV_PLUG" make loaderdumper
>> >>but that had no effect (is this right the right way?).  I think part of
>> >>the issue here is that CFLAGS is reset at the start of loader/Makefile,
>> >>so any CFLAGS (or LDFLAGS) options that are supplied when executing make
>> >>are wiped by the time the loader source is compiled.
>> >Setting CFLAGS in the environment works fine with postgis-head.
>> >The CFLAGS reset happens in PGSQL_SRC/Makefile.global, there's
>> >no easy fix for 1.0.
>> >>Should LIBICONV_PLUG be an option that is just always enabled when
>> >>USE_ICONV=1, or should it be optional?  Everything worked fine when I
>> >>added "LIBICONV_PLUG = 1" in Makefile.config, then the following lines
>> >>in loader/Makefile:
>> >>ifeq ($(LIBICONV_PLUG),1)
>> >>	override CFLAGS += -DLIBICONV_PLUG
>> >>endif
>> >I guess that LIBICONV_PLUG forces you to use the glibc version
>> >rather then libiconv, right ? This would fail on system with
>> >libiconv *only* external to libc, correct ?
>> >Mapserver solution was to always link against libiconv if present and let
>> >header file inclusion determine which version to use.
>> >I've committed a patch for the 1.0 branch allowing you to specify
>> >ICONV_LDFLAGS and ICONV_CFLAGS, please check if that would do for
>> >you. Your choice would be:
>> >Original user choice would be something like:
>> >	ICONV_CFLAGS="-I/usr/local/include" \
>> >		ICONV_LDFLAGS="-L/usr/local/lib -liconv" make
>> >Let me know if this makes it.
>> >I'd reserve changes in the HEAD branch for later, to allow for
>> >autodetection of cases in which external lib only supports iconv.
>> >Filing a bug report would help keeping track of this.
>> >Thanks.
>> >--strk;
>> >>Anyway, that's all for now.
>> >>Regards,
>> >>Mike
>> >>Mike Leahy wrote:
>> >>>Hey there,
>> >>>I think this problem might be related to a bug found with MapServer a
>> >>>while back: http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=909
>> >>>I tried commenting out the following lines in /usr/local/include/
iconv.h
>> >>>(version 1.10), and PostGIS compiled without errors:
>> >>>45: //#undef iconv_t
>> >>>46: //#define iconv_t libiconv_t
>> >>>70: //#define iconv_open libiconv_open
>> >>>80: //#define iconv libiconv
>> >>>86: //#define iconv_close libiconv_close
>> >>>96: //#define iconvctl libiconvctl
>> >>>119: //#define iconvlist libiconvlist
>> >>>I have no idea if this breaks anything...I just figured it was related
>> >>>to conflicting libraries as suggested in the MapServer bug referenced
>> >>>above.
>> >>>I'm running FC4, with the most recent upgrades.
>> >>>I hope this helps.
>> >>>Mike
>> >>>Larry Shaffer wrote:
>> >>>>strk,
>> >>>>Sorry for the lack of info on my part. I'd like to get this
working, but
>> >>>>it's no big thing until I get ready to install the upcoming PostGIS
>> >>>>1.0.6
>> >>>>version, as this is a brand new setup (PostgreSQL and all) with no real
>> >>>>data installed into yet.
>> >>>>Make for PostGIS works fine with USE_ICONV ?= 0
>> >>>>My src path is /usr/local/src/postgresql-8.1.0/contrib/postgis
>> >>>>These are the values in the PGISSRC/Makefile.config:
>> >>>>USE_PROJ ?= 1
>> >>>>PROJ_DIR ?= /usr/local
>> >>>>USE_GEOS ?= 1
>> >>>>GEOS_DIR ?= /usr/local
>> >>>>USE_JTS ?= 0
>> >>>>JTS_INCLUDES = /usr/local/include
>> >>>>JTS_LIBDIR = /usr/local/lib
>> >>>>USE_STATS=1
>> >>>>AUTOCACHE_BBOX ?= 1
>> >>>>PGSQL_SRC=/usr/local/src/postgresql-8.1.0
>> >>>>USE_ICONV ?= 1
>> >>>>(set to 0 for PostGIS make, then to 1 for shp2pgsql make)
>> >>>>LPATH=/usr/local/src/postgresql-8.1.0/contrib/postgis
>> >>>>What's in /usr/local/lib
>> >>>>libiconv_plug.so
>> >>>>libiconv.la
>> >>>>libiconv.so
>> >>>>libiconv.so.2
>> >>>>libiconv.so.2.2.0
>> >>>>What's in /usr/local/include
>> >>>>iconv.h
>> >>>>and whereis?
>> >>>>sh-2.05a# whereis libiconv
>> >>>>libiconv: /usr/local/lib/libiconv.so /usr/local/lib/libiconv.la
>> >>>>sh-2.05a# whereis iconv
>> >>>>iconv: /usr/bin/iconv /usr/local/bin/iconv /usr/include/iconv.h /usr/
>> >>>>share/man/man1/iconv.1.gz /usr/share/man/man3/iconv.3.gz
>> >>>>(Where is /usr/local/include/iconv.h? It *does* exist in /usr/local/
>> >>>>include. This could be the problem...)
>> >>>>Running  iconv -l  for /usr and /usr/local provides positive results of
>> >>>>listing encodings (i.e. both are working).
>> >>>>sh-2.05a# /usr/bin/iconv --version
>> >>>>iconv (GNU libc) 2.2.5
>> >>>>Copyright (C) 2002 Free Software Foundation, Inc.
>> >>>>Written by Ulrich Drepper.
>> >>>>sh-2.05a# /usr/local/bin/iconv --version
>> >>>>iconv (GNU libiconv 1.9)
>> >>>>Copyright (C) 2000-2002 Free Software Foundation, Inc.
>> >>>>Written by Bruno Haible.
>> >>>>I installed the libiconv-1.9.1 from GNU since it was a standalone.
>> >>>>Should I install the Standard C library (glibc-2.3.2) in /usr/local ? I
>> >>>>don't think the /usr/local extras before make command of shp2pgsql are
>> >>>>making a difference, so I don't think it's worth the effort right now.
>> >>>>See the following...
>> >>>>Here's the output from the /usr/local extras
>> >>>>(run from within contrib/postgis/loader)
>> >>>>sh-2.05a# LDFLAGS="-L/usr/local/lib -liconv" CFLAGS="-I/usr/local/
>> >>>>include" make shp2pgsql
>> >>>>make: `shp2pgsql' is up to date.
>> >>>>sh-2.05a# make clean
>> >>>>rm -f shpopen.o dbfopen.o getopt.o PQunescapeBytea.o shp2pgsql.o
>> >>>>pgsql2shp.o shp2pgsql pgsql2shp
>> >>>>gcc -g -Wall -I.. -I. -I/usr/local/src/postgresql-8.1.0/src/interfaces/
>> >>>>libpq -O2 -Wall -Wmissing-prototypes -Wpointer-arith -Winline -fno-
>> >>>>strict-aliasing -DUSE_ICONV -DFRONTEND -DSYSCONFDIR='"/usr/local/pgsql/
>> >>>>etc"' -DUSE_VERSION=81 -I/usr/local/src/postgresql-8.1.0/src/include -
>> >>>>D_GNU_SOURCE  -I/usr/local  -c -o shpopen.o shpopen.c
>> >>>>shpopen.c:176: warning: `rcsid' defined but not used
>> >>>>D_GNU_SOURCE  -I/usr/local  -c -o dbfopen.o dbfopen.c
>> >>>>dbfopen.c:200: warning: `rcsid' defined but not used
>> >>>>D_GNU_SOURCE  -I/usr/local  -c -o getopt.o getopt.c
>> >>>>D_GNU_SOURCE  -I/usr/local  -c -o PQunescapeBytea.o PQunescapeBytea.c
>> >>>>D_GNU_SOURCE  -I/usr/local  -c -o shp2pgsql.o shp2pgsql.c
>> >>>>etc"' -DUSE_VERSION=81 shpopen.o dbfopen.o getopt.o PQunescapeBytea.o
>> >>>>shp2pgsql.o -L/usr/local/src/postgresql-8.1.0/src/port -lstdc++  -
L/usr/
>> >>>>local -Wl,-rpath,/usr/local/pgsql/lib -o shp2pgsql shp2pgsql.o: In
>> >>>>function `utf8':
>> >>>>/usr/local/src/postgresql-8.1.0/contrib/postgis/loader/
shp2pgsql.c:1630:
shp2pgsql.c:1648:
shp2pgsql.c:1654:
>> >>>>collect2: ld returned 1 exit status
>> >>>>make: *** [shp2pgsql] Error 1
>> >>>>and without the /usr/local extras... just 'make shp2pgsql'...
>> >>>>exactly the same results.
>> >>>>I don't think /usr/local/include/incov.h is being located. Either way,
>> >>>>it's failing to make when using the base install of Debian
>> >>>>[linus]$ uname -a
>> >>>>Linux linus 2.4.28-grsec+w+fhs6b+gr0501+nfs+++p4+c4+gr6b-v6.188 #1 SMP
>> >>>>Fri Jan 14 11:41:59 PST 2005 i686 unknown
>> >>>>Any help would be appreciated. Thanx.
>> >>>_______________________________________________
>> >>>postgis-users mailing list
>> >>>postgis-users at postgis.refractions.net
>> >>>http://postgis.refractions.net/mailman/listinfo/postgis-users
> /"\    ASCII Ribbon Campaign
> \ /    Respect for open standards
>  X     No HTML/RTF in email
> / \    No M$ Word docs in email
