[postgis-users] COPY too slow when geometry column is indexed
Rick Schumeyer rschumeyer at ieee.org
Thu Dec 1 10:01:12 PST 2005
I'm running postgresql 8.1.0 with postgis 1.0.4 on a FC3 system, 3Ghz, 1 GB
memory.
I am using COPY to fill a table that contains one postgis geometry column.
With no geometry index, it takes about 45 seconds to COPY one file.
If I add a geometry index, this time degrades.  It keeps getting worse as
more records are
added to the table.  It was up to over three minutes per file on my most
recent test.  If I let
it run long enough, the time degrades to 7 or 8 minutes.
The problem is that each file contains about 5 - 10 minutes of data.
Eventually, I want to
add the data to the table in "real time".  So the COPY needs to take less
time than
actually generating the data.
Here is the relevant section of my postgresql.conf.
# - Memory -
shared_buffers = 5000               # min 16 or max_connections*2, 8KB each
#temp_buffers = 1000                # min 100, 8KB each
#max_prepared_transactions = 5            # can be 0 or more
# note: increasing max_prepared_transactions costs ~600 bytes of shared
memory
# per transaction slot, plus lock space (see max_locks_per_transaction).
work_mem = 20000              # min 64, size in KB
maintenance_work_mem = 20000        # min 1024, size in KB
#max_stack_depth = 2048             # min 100, size in KB
Any suggestions for improvement?
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20051201/6481ee8f/attachment.html>
