[postgis-users] change encoding of database
Paul Ramsey
pramsey at refractions.net
Thu Dec 1 19:02:22 PST 2005
You'll have to dump/restore, but it should not be painful (I am
pretty sure):
1 - create newdatabase with desired encoding
2 - pg_dump olddatabase | psql newdatabase
Should be that easy (I hope!)
P
On Dec 1, 2005, at 6:47 PM, Kralidis,Tom [Burlington] wrote:
> Hi,
> Env:
> Linux localhost 2.6.10-1.771_FC2 #1 Mon Mar 28 00:50:14 EST 2005 i686
> i686 i386 GNU/Linux
> PostgreSQL:
> $ ./psql -V
> psql (PostgreSQL) 8.0.3
> contains support for command-line editing
> PostGIS:
> devgeodb=# select postgis_full_version();
> POSTGIS="1.1.0CVS" GEOS="2.1.4" PROJ="Rel. 4.4.9, 29 Oct 2004"
> USE_STATS DBPROC="0.3.0" RELPROC="0.3.0"
> (1 row)
> I have a database which I created and has a bunch of tables/data, both
> spatial and aspatial.
> As it happens, I messed up on the character encoding.
> Questions:
> 1./ What's the best way to change the encoding of the database? I'm
> trying to avoid manually reloading things
> 2./ How will, if at all, spatial tables be affected?
> Thanks
> ..Tom
> Tom Kralidis
> Senior Systems Scientist
> Environment Canada
> Tel: +01-905-336-4409
> http://www.ec.gc.ca/
> postgis-users mailing list
