[postgis-users] avpgcon - workaround/fix
uli mueller
uli.mueller at gmx.ch
Fri Dec 2 15:52:15 PST 2005
Armin
Is there still a link to downlaod avpgcon? If not I'd also like to ask
for a copy.
Nice feature would be if you supported schemas different from public. In
my version (0.6.3) tables for all schemas are listed without the schema
identifier. In order to use them I have to add the schema name manually
to the table name in the edit box (ok, that is really a minor bug).
Uli
Robert Burgholzer wrote:
> Armin,
> That'd be great. Sorry I didn't contact you first, I just assumed you no
> longer used it.
> r.b.
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
> Armin Burger
> Sent: Friday, December 02, 2005 2:43 PM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] avpgcon - workaround/fix
> Robert
> in the last time I had again some looks on avpgcon. I already modified
> some parts to work with newer versions of PostGIS. I still have to
> remove a bug when accessing Postgres on other ports than 5432 and modify
> the identify function. If you're interested I can send you a copy when
> it'll be mainly done.
> Armin
>>This from the "WayBack Machine":
>>Don't know if anyone is still using avpgcon.avx, but I still use
> ArcView
>>3.3 a bit, and so use avpgcon. This fix relates to that.
>>When loading a shape from postgis an error is thrown when avpgcon
> tests
>>to see if the shape is within the current extent, i.e.:
>>SELECT gid, shapename, the_geom
>>FROM pg_table
>>WHERE
>>the_geom && GeometryFromText('BOX3D(-356801.233852
>>3928796.210200,649032.548074 4927586.338191)'::box3d,-1)
>>Seems that the newer version of geometryFromText don't like the Box3d,
>>however, if you simply change the "GeometryFromText" to "Transform",
> as
>>in :
>>FROM pg_table
>>WHERE
>>the_geom && transform('BOX3D(-356801.233852
>>Everything appears to be hunky-dory.
>>Robert W. Burgholzer
>>Nonpoint Source Data Analyst
>>University of Maryland, College Park
>>Chesapeake Bay Program Office
>>410 Severn Avenue, Suite 305B
>>Annapolis, MD, 21403
>>Phone: (410) 267-5779
>>rburghol at chesapeakebay.net <mailto:rburghol at chesapeakebay.net>
>>http://www.chesapeakebay.net/
>>_______________________________________________
>>postgis-users mailing list
>>postgis-users at postgis.refractions.net
>>http://postgis.refractions.net/mailman/listinfo/postgis-users
geOps GeoInformatics
D-79100 Freiburg
