[postgis-users] Re: function to find UTM zone SRID from POINT
Alex Mayrhofer axelm-postgis at nona.net
Mon Dec 5 02:19:07 PST 2005
Patrick wrote:
> This depends on how your point is defined. If it is lat/long on WGS84, then
> it is pretty straightforward. The zone number is calculated as (long + 186)
> div 6. Positive latitudes add an N, negative an S. UTM zones have sequential
> SRIDs. So if you find the starting SRID for zone 01N and 01S and add the
> zone number -1, you have the answer to your question.
Ok, that would be pretty straightforward - probably with the exception of
points which are _exactly_ on a zone border - which zone should they use?
Essentially, they would show up in both zones on  the "border of the map".
However, i'll use the centroid of a geometry to decide about the zone. And
my data is WGS84, so no problem here...
> Further problems lie in the selection of datum. UTM has no fixed datum and
> you will thus find many entries for a given zone number in spatial_ref_sys,
> each having a different datum. Using the original EPSG tables instead of
> spatial_ref_sys gives you more options for analysis, but it is no easy
> solution. This wheel has not been invented yet, but I am working on it (see
> threads on 18 October and 10 November).
phew - didn't think of that. Out of my scope, fortunately, because i'll be
fine with the "start SRID + zone offset" approach.
thanks for the valueable insight.
Alex Mayrhofer
