[postgis-users] inserting records via web-client
Bart van den Eijnden BEN at Syncera-ITSolutions.NL
Mon Dec 5 23:02:46 PST 2005
I would say Geoserver is mostly WFS but also does WMS. For Mapserver I would state it the other way round, Mapserver does mostly WMS but also does WFS.
Geoserver is WFS-T (transactional), Mapserver is a read-only WFS. And yes Geoserver is J2EE whereas Mapserver is C CGI.
Wrt the 3-tier, the 2 deepmost tiers (spatial db and WFS-T) could run on the same machine, or with a fast network in between them, so performance would not really be worse. The architecture would be easier to maintain and you could more easily plugin replacement components (a different WFS-T) if needed.
Hope this helps.
Best regards,
Bart
Syncera IT Solutions
Postbus 270
2600 AG  DELFT
tel.nr.: 015-7512436
email: BEN at Syncera-ITSolutions.nl
>>> hydromap at gmail.com 12/06/05 5:53 AM >>>
Whoa! Thanks guys... sounds like its gonna be trivial.
What would be some advantages to taking the abstract 3 tier approach? Any
performance issues?
Also (sorry this may be slightly off-topic) am I correct in my understanding
that Geoserver is kinda like a Java substitute to Mapserver?
cheers
sb
On 12/6/05, Paul Ramsey <pramsey at refractions.net> wrote:
> I think both chameleon (maptools.org) and mapbender ( mapbender.org)
> allow client side digitization. From there it is a very small amount
> of scripting to post the result back to a trivial PHP or Java or
> Python or Whatever script that inserts the result into the database.
> Or, as Tom wrote, you could use an even more abstracted
> architecture.  We've done this using a proprietary web UI a couple
> times, OpenIMF (moximedia.com) (where the "open" stands for open
> standards, not open source).
> P
> On 5-Dec-05, at 4:19 PM, sab bman wrote:
> > Hi
> > I am currently trying to assess how difficult it would be to insert a
> > user-drawn shapes+attributes into a PostGIS back-end. Using perhaps
> > SVG or javascript enable web-client. Does anyone know if this has been
> > achieved?
> > thanks
> > Shoaib Burq
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
