[postgis-users] problem compiling postgis 1.0.5 and 1.0.6
strk at refractions.net
Wed Dec 7 03:19:56 PST 2005
On Wed, Dec 07, 2005 at 12:17:58PM +0100, Guillaume Sueur wrote:
> Hi,
> an old problem shows up again.
> I've upgraded from postgresql 8.0 to 8.1 and it went ok, the postmaster
> is running again.
> But when I try to compile postgis 1.0.6 or 1.0.5 from the contrib
> directory, I have the following message : usr/bin/ld: can't find -lpq
> I checked these points :
> - libpq.so is under /usr/local/pgsql/lib
> - /usr/local/pgsql/lib is in /etc/ld.so.conf
> - ldconfig has been run after that.
> and I still have the same problem.
> Any idea ?
The postgresql source must be configured and built.
Postgis 1.0.x still uses data in pgsql source tree.
--strk;
/"\ ASCII Ribbon Campaign
\ / Respect for low technology.
X Keep e-mail messages readable by any computer system.
/ \ Keep it ASCII.
