[postgis-users] postgis 0.9.2 + postgresql 8.1.0 crash
alex bodnaru
alexbodn at 012.net.il
Wed Dec 7 16:30:27 PST 2005
hi strk,
i'm fighting hard to add postgis-0.9 support in debian, arguing
upgrading is more than dump-restore.
as debian is a too prudent distribution, gdal distributed in
debian/testing does, in fact, support only postgis-0.9 (as far as i tested).
btw, what about keeping the way to store geometry as a parameter, with
functions transparently translating from/to main wkb?
this will work for all postgis since 0.x.
alex
strk at refractions.net wrote:
> On Thu, Dec 08, 2005 at 01:38:51AM +0200, alex bodnaru wrote:
>>hi friends,
>>there is a problem with postgis 0.9.2 and postgresql 8.1.0.
>>strk has resolved it in cvs branch for postgis 0.9.
>>hope this helps,
> Oh, I completely forgot that... well, do you guys think
> it's worth taking 0.9.3 out ?
> --strk;
>>alex
>>Christian Grau wrote:
>>>>--- Ursprüngliche Nachricht ---
>>>>Von: strk at refractions.net
>>>>An: postgis-users at postgis.refractions.net
>>>>Betreff: Re: [postgis-users] postgis 0.9.2 + postgresql 8.1.0 crash
>>>>Datum: Wed, 7 Dec 2005 12:15:03 +0100
>>>>On Wed, Dec 07, 2005 at 11:27:12AM +0100, Christian Grau wrote:
>>>>>hello list,
>>>>>i have installed a postgresql 8.1.0 + postgis 0.9.2 + mapserver 4.6.1
>>>>>importing shapes and postgis functions like length,area .. does fine.
>>>>>but showing layer with mapserver crashes ????
>>>>>whats the problem :-(
>>>>Maybe mapserver requires postgis-1.0 ?
>>>>There's been deep changes between 0.9 and 1.0, you should
>>>>check mapserver dox about this.
>>>>Also, you might try to enable statement print in your backend
>>>>and try the same query manually.
>>>>--strk;
>>>>/"\ ASCII Ribbon Campaign
>>>>\ / Respect for low technology.
>>>> X Keep e-mail messages readable by any computer system.
>>>>/ \ Keep it ASCII.
>>>>_______________________________________________
>>>>postgis-users mailing list
>>>>http://postgis.refractions.net/mailman/listinfo/postgis-users
>>>hi strk,
>>>mapserver 4.6.1 works with postgis 0.9.2.
>>>is there a problem with postgis 0.9.2 and postgresql 8.1.0 ???
>>>thanks
>>>christian
