[postgis-users] freeBSD GEOS upgrade problem with PostGIS
Stephen Woodbridge woodbri at swoodbridge.com
Sat Dec 10 05:49:44 PST 2005
The last two times I have upgraded my system using portupgrade I have
had library problems with PostGIS.
After doing the upgrade libgeos.so.X changes to reflect the new library
and this breaks PostGIS thusly:
select postgis_full_version();
ERROR:  could not load library "/usr/local/lib/liblwgeom.so.1": dlopen
'/usr/local/lib/liblwgeom.so.1' failed. (Shared object "libgeos.so.2"
not found, required by "liblwgeom.so.1")
CONTEXT:  SQL statement "SELECT  postgis_lib_version()"
PL/pgSQL function "postgis_full_version" line 10 at select into variables
I have hacked a fix by doing adding in /usr/local/lib directory
on the upgrade to GEOS 2.1.4
   ln -s libgeos.so.3 libgeos.so.2
and on this current upgrade to GEOS 2.2.0
   ln -s libgeos.so.4 libgeos.so.2
so I get:
"POSTGIS="1.0.4" GEOS="2.2.0" PROJ="Rel. 4.4.9, 29 Oct 2004" USE_STATS
DBPROC="0.3.0" RELPROC="0.3.0""
Soooo, I guess my question(s) are:
Is this bad?
Why is this happening?
There is a PostGIS 1.0.4_2 that I have not upgraded to yet because I
wanted to check which version I was on. Now I think it is safe to
upgrade that since I'm already on 1.0.4
Strk mentioned a 1.0.6, should I just wait until that propagates to the
ports?
Thanks,
   -Steve W.
