[postgis-users] [ANN] GEOS 2.2.0/Postgis 1.0.6 packages for Ubuntu Breezy Badger
Blair Zajac blair at orcaware.com
Sat Dec 10 12:24:01 PST 2005
For people on Ubuntu Breezy Badger, I've updated my packages to the latest
versions of:
- GEOS 2.2.0.  This is up from Ubuntu's 2.1.1-2ubuntu1.  The package was pulled
from Debian's 2.1.4-2 and updated with GEOS 2.2.0.  This build renamed the
libgeos2c2 package to libgeos2c2a for their libstdc++ transition.
- Proj.  The same major version 4.4.9, but it now includes built-in datum
conversion support.  This was pulled from Debian's upstream version.  See
http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=339470 for more information.
- Postgis 1.0.6.  Up from 1.0.5.
Installation instructions:
1) Add to the top of your /etc/apt/sources.list the following two lines:
deb http://www.orcaware.com/packages/ubuntu/ breezy/
deb-src http://www.orcaware.com/packages/ubuntu/ breezy/
2) Run
apt-get update
3) Run
apt-get install libpostgis1-pg8.1
This installs the main packages required for Postgis 1.0.6 with Postgresql 8.1.0.
Note that if you have any of my previous packages installed, you cannot just run
'apt-get dist-upgrade' as it won't upgrade libpostgis1-pg8.1 because the new
libpostgis1-pg8.1 depends upon libgeos2c2a, but apt-get won't remove the older
libgeos2c2.  So you will need to run 'apt-get install libpostgis1-pg8.1' to get
apt-get to remove libgeos2c2 and install libgeos2c2a and libpostgis1-pg8.1.
For completeness sake, here's the complete list of packages I've compiled:
libgeos-dev_2.2.0-0zajac1_i386.deb
libgeos-doc_2.2.0-0zajac1_all.deb
libgeos2c2a_2.2.0-0zajac1_i386.deb
libpg-java_8.1-404-0zajac2_all.deb
libpgjava_8.1-404-0zajac2_all.deb
libpostgis-common_1.0.6-0zajac1_all.deb
libpostgis-doc_1.0.6-0zajac1_all.deb
libpostgis-java-debug_1.0.6-0zajac1_all.deb
libpostgis-java_1.0.6-0zajac1_all.deb
libpostgis-utils-pg8.1_1.0.6-0zajac1_i386.deb
libpostgis1-examples_1.0.6-0zajac1_all.deb
libpostgis1-pg8.1_1.0.6-0zajac1_i386.deb
libecpg-compat2_8.1.0-3zajac1_i386.deb
libecpg-dev_8.1.0-3zajac1_i386.deb
libecpg5_8.1.0-3zajac1_i386.deb
libpgtypes2_8.1.0-3zajac1_i386.deb
libpq-dev_8.1.0-3zajac1_i386.deb
libpq4_8.1.0-3zajac1_i386.deb
postgresql-8.1_8.1.0-3zajac1_i386.deb
postgresql-client-8.1_8.1.0-3zajac1_i386.deb
postgresql-contrib-8.1_8.1.0-3zajac1_i386.deb
postgresql-doc-8.1_8.1.0-3zajac1_all.deb
postgresql-plperl-8.1_8.1.0-3zajac1_i386.deb
postgresql-plpython-8.1_8.1.0-3zajac1_i386.deb
postgresql-pltcl-8.1_8.1.0-3zajac1_i386.deb
postgresql-server-dev-8.1_8.1.0-3zajac1_i386.deb
postgresql-common_36-0zajac1_all.deb
Regards,
Blair
Blair Zajac, Ph.D.
<blair at orcaware.com>
Subversion and Orca training and consulting
http://www.orcaware.com/svn/
