[postgis-users] Need loader to build WITHOUT all the other stuff
Ries van Twisk postgis at rvt.dds.nl
Mon Dec 19 18:28:38 PST 2005
Stephen Woodbridge wrote:
> strk at refractions.net wrote:
>> On Mon, Dec 19, 2005 at 03:32:30PM -0500, Stephen Woodbridge wrote:
>>> Hi all,
>>> It would REALLY be great if I could get shp2pgsql to build all by
>>> itself. I have a lot of systems that do not have postgres/postgis
>>> installed on them but need to be able to load data into a remote
>>> database. These are often not even the same arch as the database box.
>>> Is there any change of making this compile without having to
>>> download and build the whole sheebang?
>> You don't have to build the whole sheebang, but you do
>> have to download it.
maby this is something for you:
http://fwtools.maptools.org/
Works out of the box for windows and Linux (I use the linux version).
It doesn't contain shp2pgsql but does contain ogr2ogr to load quite a
lot of data directly into postgresql.
including shape files, vmap0, vmap1 etc etc..... or to convert from one
format to a other format...
cheers,
Ries
