[postgis-users] postgis install probs under OpenSuse 10.0
Mark Cave-Ayland m.cave-ayland at webbased.co.uk
Tue Dec 20 01:31:00 PST 2005
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-
> bounces at postgis.refractions.net] On Behalf Of Poizot Emmanuel
> Sent: 20 December 2005 08:11
> To: PostGIS Users Discussion
> Subject: [postgis-users] postgis install probs under OpenSuse 10.0
> Hi,
> I try to install postgis under OpenSuse 10.0.
> I did downloaad the sources of postgres and compile it without any
> problems.
> I downloaded postgis and decompresses it in the contrib folder of
> postgres.
> Make and make install works well (no errors).
> I started postgres :
> postmaster -D /usr/local/pgsql/data >logfile 2>&1 &
> I did create a database :
> createdb test
> then I attached plsql language to my newly database :
> |createlang plpgsql test
> but when I tape for the next step :
> ||psql -d test -f lwpostgis.sql
> I've got a lots of messages :
> |psql:lwpostgis.sql:30: NOTICE: le type «histogram2d» n'est pas encore
> défini
> DÉTAIL : Création de la définition d'un shell type.
> psql:lwpostgis.sql:30: ERREUR: n'a pas pu accéder au fichier
> «$libdir/liblwgeom.so.1.0» : Aucun fichier ou répertoire de ce type
> psql:lwpostgis.sql:35: ERREUR: La transaction courante est annulée, les
> commandes sont ignorées jusqu'à la fon du bloc de la transaction
> sql:lwpostgis.sql:2955: ERREUR: La transaction courante est annulée, les
> psql:lwpostgis.sql:2961: ERREUR: La transaction courante est annulée,
> les commandes sont ignorées jusqu'à la fon du bloc de la transaction
> ROLLBACK
> is this a problem of path, and if so wich one is missing ?
> Regards
Hi Emmanuel,
The problem is that PostgreSQL cannot find your liblwgeom.so.1.0 file. The
directory in which PostgreSQL expects to find it can be found by typing:
pg_config --libdir
Kind regards,
Mark.
WebBased Ltd
17 Research Way
Plymouth
PL6 8BT
T: +44 (0)1752 797131
F: +44 (0)1752 791023
http://www.webbased.co.uk
http://www.infomapper.com
http://www.swtc.co.uk
This email and any attachments are confidential to the intended recipient
and may also be privileged. If you are not the intended recipient please
delete it from your system and notify the sender. You should not copy it or
use it for any purpose nor disclose or distribute its contents to any other
person.
