[postgis-users] transform() does not do work for NGO1948 zone III -> WGS84 longlat (epsg:27393->epsg:4326)
strk at refractions.net strk at refractions.net
Wed Dec 21 00:19:19 PST 2005
On Tue, Dec 20, 2005 at 04:56:47PM -0500, Frank Warmerdam wrote:
> Error -38 is:
>  	"failed to load NAD27-83 correction file",  	/* -38 */
> So basically, if the datum shift files are not found, then the
> code fallback to trying a conversion without the datum shift.
Thank you Frank,
maybe we should raise a WARNING in that case ? I mean, is
"shift files not found" condition a sign of incomplete
installation of PROJ4 ?
--strk;
 /"\    ASCII Ribbon Campaign
 \ /    Respect for low technology.
  X     Keep e-mail messages readable by any computer system.
 / \    Keep it ASCII.
