[postgis-users] importing 3d shapefiles
Mark Wright
sparkymeister at gmail.com
Wed Dec 28 14:01:54 PST 2005
I think I figured this one out. I haven't tried this with a line
layer, but I got a 3d point layer imported directly into postgres by
adding DIM=3 to v.out.ogr. The postgred docs say that it defaults to
3d so either grass defaults to 2d when exporting or postgis defaults
to 2d. I'll look into this.
Mark
On 12/28/05, strk at refractions.net <strk at refractions.net> wrote:
> On Mon, Dec 26, 2005 at 12:51:46AM -0800, Mark Wright wrote:
> shp2pgsql shipped from version 1.0 up should use all of
> Shapefile-defined dimensions. If this is not the
> case I'd call it a bug. You can invoke shp2pgsql w/out args
> to see the RCSID of it, which can then be mapped to a release
> (not that easy, but let us know and we'll tell you)
> --strk;
> postgis-users mailing list
