[postgis-users] problem with shp2pgsql
Frank Koormann frank.koormann at intevation.de
Thu Dec 29 01:22:00 PST 2005
Just for the records,
* Stephen Woodbridge <woodbri at swoodbridge.com> [051228 21:33]:
> henok tadesse wrote:
> >thanks  every body,
> >i actually have already loaded all the shape files  in the folder where
> >the shp2pgsql exists.
> >    ./shp2pgsql -s 26911  River.shp River myschema.myRiverdb > River.sql
> >but still it returns >> bash: River.sql: Permission denied
> ./shp2pgsql -s 26911  River.shp River myschema.myRiverdb > ~/River.sql
> >    2) you have only copied the *.shp file to the loader directory, but
> >    not the other associated (and needed fiel). These include at least
> >    *.dbf and *.shx , in many cases also *.sbn, *.prj or *.sbx
the most common way IMHO is not to place your data where your filter
programs are located but to call the filter from where your data is
located, e.g. under /home/myname/mydata :
/usr/lib/postgresql/bin/shp2pgsql -s 26911  River.shp River myschema.myRiverdb > River.sql
If used frequently either copy shp2pgsql to a directory specified in the
PATH environment variable or extend your PATH to the directory where
shp2pgsql is located.
HTH,
        Frank Koormann
Frank Koormann                             <frank.koormann at intevation.de>
 Professional Service around Free Software       (http://intevation.net/)
 FreeGIS Project                                 (http://freegis.org/)
