[postgis-users] Index scan performance difference between 0.8 and rc1; (fwd)
strk at refractions.net
Tue Feb 1 03:03:23 PST 2005
On Mon, Jan 31, 2005 at 03:53:20PM -0800, Ron Mayer wrote:
> On Mon, 31 Jan 2005, Ron Mayer wrote:
> > Should I expect index scans to be quite a bit slower with RC2 than 0.8, or
> > am I doing something else wrong?
> Hmm.... the performance changes a lot if I use find_srid() or "-1" when defining my BOX3D; even though my srid is -1.
> Is this a good hint what my problem may be?
> Ron
Mmm.. this is interesting.
I've tested a sample query three times, with find_srid defined as
VOLATILE, STABLE, IMMUTABLE. Here are the results:
VOLATILE: Total runtime: 1096.708 ms
STABLE: Total runtime: 42.457 ms
IMMUTABLE: Total runtime: 18.457 ms
Postgis < 1.0.0RC2 had find_srid defined with (iscachable).
Since 8.0.0 PostgreSQL has splitted the iscachable keywork in
STABLE/IMMUTABLE to define in-query cachability and in-session
cachability:
For details:
http://www.postgresql.org/docs/current/static/sql-createfunction.html
In RC2 I've defined find_srid as STABLE, and defined STABLE to
be non-cachable for PostGRESQL<800.
If you want to try it out:
-- IMMUTABLE
update pg_proc set provolatile = 'i' where proname = 'find_srid';
-- STABLE
update pg_proc set provolatile = 's' where proname = 'find_srid';
-- VOLATILE
update pg_proc set provolatile = 'v' where proname = 'find_srid';
I'll make it IMMUTABLE for now, to also keep it cachable in PG<800.
--strk;
> fli=# explain analyze SELECT * from rtgr.lines WHERE the_geom && setSRID('BOX3D(-84.47104 30.3775,-84.16479 30.5875)'::BOX3D, -1);
> QUERY PLAN
> Index Scan using rtgr_lines__gist on lines (cost=0.00..21096.85 rows=5916 width=71) (actual time=0.118..94.982 rows=15706 loops=1)
> Index Cond: (the_geom && '01030000000100000005000000E7C6F484251E55C0713D0AD7A3603E40E7C6F484251E55C06666666666963E404D2D5BEB8B0A55C06666666666963E404D2D5BEB8B0A55C0713D0AD7A3603E40E7C6F484251E55C0713D0AD7A3603E40'::geometry)
> Total runtime: 104.429 ms
> (3 rows)
> fli=# explain analyze select * from rtgr.lines WHERE the_geom && setSRID('BOX3D(-84.47104 30.3775,-84.16479 30.5875)'::BOX3D, find_srid('','rtgr.lines','the_geom') );
> QUERY PLAN
> Index Scan using rtgr_lines__gist on lines (cost=0.00..14.04 rows=3 width=71) (actual time=0.313..808.014 rows=15706 loops=1)
> Index Cond: (the_geom && setsrid('01030000000100000005000000E7C6F484251E55C0713D0AD7A3603E40E7C6F484251E55C06666666666963E404D2D5BEB8B0A55C06666666666963E404D2D5BEB8B0A55C0713D0AD7A3603E40E7C6F484251E55C0713D0AD7A3603E40'::geometry, find_srid(''::character varying, 'rtgr.lines'::character varying, 'the_geom'::character varying)))
> Total runtime: 821.575 ms
> (3 rows)
> fli=# select find_srid('','rtgr.lines','the_geom') ;
> find_srid
> -1
> (1 row)
> postgis-users mailing list
