[postgis-users] Concern about GEOMUNION() results
James G Wilkinson jgw at alpinegeophysics.com
Tue Feb 1 08:51:52 PST 2005
I am using PostgreSQL v.7.4.2, PostGIS 0.9.0, PROJ v.4.4.7, and GEOS
v.2.1.1.
I have prepared two spatially enabled tables called "test" and "test2."
"test" is a
single polygon, and "test2" is a single line segment (see below for
their geometries).
When I perform a union of the two geometries (also shown below), I
expected to
get a GEOMETRYCOLECTION with three line segments and the polygon.  Instead,
I received only two line segments and a polygon (results shown below).
The third
line segment that I expected was as follows:
LINESTRING(-97 42.04,-97.05 42.1)
Is my expectation wrong?
Regards,
Jim
beta_jgw=# select * from spatial.test2;
 gid |                  the_geom
   1 | SRID=4267;LINESTRING(-96.8 41.8,-97.3 42.4)
(1 row)
beta_jgw=# select * from spatial.test;
 gid |                            the_geom
   1 | SRID=4267;POLYGON((-97 42,-97.1 42,-97.1 42.1,-97 42.1,-97 42))
beta_jgw=# select geomunion(a.the_geom, b.the_geom) from spatial.test a,
spatial.test2 b;
                             geomunion
SRID=-1;GEOMETRYCOLLECTION(LINESTRING(-96.8 41.8,-97 42.04),
LINESTRING(-97.05 42.1,-97.3 42.4),
POLYGON((-97 42,-97.1 42,-97.1 42.1,-97.05 42.1,-97 42.1,-97 42.04,-97 42)))
(1 row)
