[postgis-users] Buggy transform() function in 1.0RC1 ?
RIBOT, Nicolas nicolas.ribot at astrium.eads.net
Wed Feb 2 06:46:12 PST 2005
Hello,
I've noticed an error when transforming from WGS84 to Lambert II Etendu
(SRID=27582) with the new postgis version.
The projected polygon presents a 2.33° East shift from the expected result.
This shift corresponds to the difference between Greenwich and the french
reference meridian.
the result was correct with previous Postgis versions.
I've seen that the spatial reference systems definitions have changed in the
new release.
the values for the Lambert II system seem to be correct.
Is it a Proj4 problem or something I don't do correctly ?
(I attach to this message a document summarizing the tests I did with both
Postgis and Jump. It contains system informations).
Thanx
Nicolas Ribot
CE COURRIER ELECTRONIQUE EST A USAGE STRICTEMENT INFORMATIF ET NE SAURAIT ENGAGER DE QUELQUE MANIERE QUE CE SOIT EADS ASTRIUM SAS, NI SES FILIALES.
SI UNE ERREUR DE TRANSMISSION OU UNE ADRESSE ERRONEE A MAL DIRIGE CE COURRIER, MERCI D'EN INFORMER L'EXPEDITEUR EN LUI FAISANT UNE REPONSE PAR COURRIER ELECTRONIQUE DES RECEPTION. SI VOUS N'ETES PAS LE DESTINATAIRE DE CE COURRIER, VOUS NE DEVEZ PAS L'UTILISER, LE CONSERVER, EN FAIRE ETAT, LE DISTRIBUER, LE COPIER, L'IMPRIMER OU EN REVELER LE CONTENU A UNE TIERCE PARTIE.
This email is for information only and will not bind EADS Astrium SAS in any contract or obligation, nor its subsidiaries.
If you have received it in error, please notify the sender by return email. If you are not the addressee of this email, you must not use, keep, disseminate, copy, print or otherwise deal with it.
