[postgis-users] About Invalid OGC WKT Error
strk at refractions.net
Wed Feb 2 08:40:46 PST 2005
On Thu, Feb 03, 2005 at 01:37:19AM +0900, Koji Yano wrote:
> Hello list.
> After I upgraded PostGIS to 1.0.0RC2 from 0.9.1,
> I have some problems in working with PostGIS.
Did you also upgrade postgis scripts ?
Can you show the output of SELECT postgis_full_version() ?
--strk;
> Example1:
> There is a table that contains id, name, geom fields.
> # INSERT INTO [table]
> VALUES(1,'test',geometryfromtext('POLYGON((135.45......))',4326);
> ERROR: Invalid OGC WKT (does not start with P,L,M or G)
> I think it starts with P...Do I get wrong?
> Example2:
> I ran shp2pgsql and imported some shape files successfully.
> When I use only 'Select the_geom', I got a result
> like 0106000020E610000001000000010300000001000000660000009C9FD6D...
> Although I can see proper WKT data by 'Astext' function,
> the same message(Invalid...) appears when I try to view geometry data of
> PostGIS by QGis.
> Environments are following.
> Turbolinux 10
> PostgreSQL 8.0.1
> PostGIS 1.0.0rc-2
> Proj4.4.9
> GEOS 2.0.1
> shp2pgsql support UTF-8
> I did not have any problems about installing.
> I appliciate your help.
> Koji Yano
> http://www.officeyano.net
> postgis-users mailing list
