[postgis-users] About Invalid OGC WKT Error
Kralidis,Tom [Burlington] Tom.Kralidis at ec.gc.ca
Wed Feb 2 15:22:56 PST 2005
Here's what shows up in my error logs when MapServer attempts to access
when I have MapServer in debugging mode:
# MapServer def
DATA "the_geom from service_endpoints"
# error_log
[Wed Feb 02 18:45:22 2005] [error] [client 192.75.68.5] [Wed Feb  2
18:45:22 2005].363256
msPOSTGISLayerOpen called datastatement: the_geom from service_endpoints
18:45:22 2005].364533
MSPOSTGISLayerOpen -- shared connection not available.
18:45:22 2005].399054
msConnPoolRegister(service_endpoints,user=postgres
dbname=devgeodb,0x8305d20)
18:45:22 2005].400004
msPOSTGISLayerFreeItemInfo called
18:45:22 2005].400676
msPOSTGISLayerWhichShapes called
18:45:22 2005].401341
msPOSTGISLayerParseData: unique column = OID, srid='', geom_column_name
= the_geom, table_name=service_endpoints
18:45:22 2005].403436
query_string_0_6:DECLARE mycursor BINARY CURSOR FOR SELECT
asbinary(force_collection(force_2d(the_geom)),'NDR'),OID::text from
service_endpoints WHERE the_geom && setSRID('BOX3D(-141.089
36.392987,-52.089 89.784987)'::BOX3D,
find_srid('','service_endpoints','the_geom') )
18:45:22 2005].440329
18:45:22 2005].441009
msPOSTGISLayerResultClose: the_geom from service_endpoints
18:45:22 2005].442809
msPOSTGISLayerClose datastatement: the_geom from service_endpoints
18:45:22 2005].443538
msPOSTGISLayerClose -- query_result is NULL
18:45:22 2005].444325
msConnPoolRelease(service_endpoints,user=postgres
18:45:22 2005].445100
msConnPoolClose(user=postgres dbname=devgeodb,0x8305d20)
...one thing I noticed was that SRID didn't get set.  When I tried to
set this explicitly in MapServer (i.e. adding "USING SRID=4326"), the
SRID showed up in the logfile, but other than that the output from the
log was identical.
Any hints?
PS -- I'm not sure where this is best posted to: mapserver-users or
postgis-users
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of Kralidis,Tom [Burlington]
> Sent: Wednesday, 02 February, 2005 13:31
> To: PostGIS Users Discussion
> Subject: RE: [postgis-users] About Invalid OGC WKT Error
> > > MapServer connects via (user config):
> > > DATA "the_geom from table_name"
> > > Does one need to pass a function (like asEWKT(the_geom from
> > table) on
> > > this?  I'm not sure how this is evaluated in the MapServer
> > / PostGIS
> > > connector code itself, though.
> > I think it should be transparent. Did you have problems ? --strk;
> Yes, I can't see any data when requesting from MapServer
> WFS/WMS.  I can't however, see the table structure through
> WFS DescribeFeatureType, so that tells me it's connecting and
> can see the table schema, but can't fetch the data.  Any suggestions?
> I'm using MapServer CVS and PostGIS 1.0.0RC2
> postgis-users mailing list postgis-users at postgis.refractions.net
