[postgis-users] Bad query optimizer misestimation because of TOAST tables
Markus Schaber schabios at logi-track.com
Thu Feb 3 05:59:25 PST 2005
Hi, all,
Markus Schaber schrieb:
> As a small workaround, I could imagine to add a small additional column
> in the table that contains the geometry's bbox, and which I use the &&
> operator against. This should avoid touching the TOAST for the skipped rows.
For your personal amusement: I just noticed that, after adding the
additional column containing the bbox and running VACUUM FULL, the table
now has a size of 4 pages, and that's enough for the query optimizer to
choose an index scan. At least that saves us from modifying and
redeploying a bunch of applications to use the && bbox query:-)
Markus
markus schaber | dipl. informatiker
logi-track ag | rennweg 14-16 | ch 8001 zürich
phone +41-43-888 62 52 | fax +41-43-888 62 53
mailto:schabios at logi-track.com | www.logi-track.com
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050203/fa3a14e1/attachment.pgp>
