[postgis-users] Concern about GEOMUNION() results
James G Wilkinson
jgw at alpinegeophysics.com
Thu Feb 3 09:39:33 PST 2005
Strk,
>>I am using PostgreSQL v.7.4.2, PostGIS 0.9.0, PROJ v.4.4.7, and GEOS
>>v.2.1.1.
>>I have prepared two spatially enabled tables called "test" and "test2."
>>"test" is a
>>single polygon, and "test2" is a single line segment (see below for
>>their geometries).
>>When I perform a union of the two geometries (also shown below), I
>>expected to
>>get a GEOMETRYCOLECTION with three line segments and the polygon. Instead,
>>I received only two line segments and a polygon (results shown below).
>>The third
>>line segment that I expected was as follows:
>>LINESTRING(-97 42.04,-97.05 42.1)
>>Is my expectation wrong?
>Yes.
>The missing segment of the line is 'absorbed' by the
>polygon it overlaps.
>If you want your third line you need the intersection of you the
>input.
Thanks for the insight. I am still stuck in my Arc/Info frame of mind
(i.e., use of the
ARC/Info IDENTITY function...I think that is the function...oh, well).
At least I am
getting a bit more savy in the use of PostGIS. Thanks again.
Regards,
Jim
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050203/abdb9159/attachment.html>
