[postgis-users] About Invalid OGC WKT Error
strk at refractions.net
Fri Feb 4 00:37:04 PST 2005
On Fri, Feb 04, 2005 at 09:52:02AM +0900, Koji Yano wrote:
> strk at refractions.net wrote:
> > Is the lwpostgis.sql you loaded the one which came from
> > RC1 or RC2 ?
> Sorry to be late to reply.
> Your addices are just what I needed.
> I created new database ,loaded lwpostgis.sql from RC2 and tested that.
> Then I can insert data by the same SQL successfully.
> Now I have a feeling that I made a mistake during upgrading.
> Maybe in uploading dumpfiles when I upgraded PostgreSQL 8.0.0 to 8.0.1.
> Thank you for your help.
Basically *fromwkb and *fromtext functions changed signature
between RC1 and RC2, so you need to drop and recreate them
for a clean upgrade.
--strk;
> > Can you post the output of this queries ?
> > # SELECT proname, proargtypes from pg_proc where proname like
> > '%fromtext' or proname like '%fromwkb';
> > # SELECT oid, typname from pg_type where typname = 'geometry'
> > or typname = 'bytea' or typname = 'text';
> > --strk;
> Here is what I get.
> # SELECT proname, proargtypes FROM pg_proc WHERE proname like
> proname | proargtypes
> geomcollfromtext | 38597 23
> geomcollfromwkb | 38597 23
> geometryfromtext | 38597
> geometryfromtext | 38597 23
> geomfromtext | 38597
> geomfromtext | 38597 23
> geomfromwkb | 17
> geomfromwkb | 17 23
> linefromtext | 38597
> linefromtext | 38597 23
> linefromwkb | 38597 23
> linefromwkb | 38597
> linestringfromtext | 38597
> linestringfromtext | 38597 23
> linestringfromwkb | 38597 23
> mlinefromtext | 38597 23
> mlinefromwkb | 38597 23
> mpointfromtext | 38597 23
> mpointfromwkb | 38597 23
> mpolyfromtext | 38597 23
> mpolyfromwkb | 38597 23
> multilinefromwkb | 38597 23
> multilinestringfromtext | 38597
> multilinestringfromtext | 38597 23
> multipointfromtext | 38597 23
> multipointfromwkb | 38597 23
> multipolyfromwkb | 38597 23
> multipolygonfromtext | 38597 23
> polyfromwkb | 38597
> polygonfromwkb | 38597 23
> (54 rows)
> # SELECT oid, typname FROM pg_type WHERE typname = 'geometry' or
> typname='bytea' or typname='text';
> oid | typname
> 17 | bytea
> 25 | text
> 38597 | geometry
> (3 rows)
> And here is the output of same queries from new created database.
> I think this is the proper result.
> gistest2=# SELECT proname, proargtypes FROM pg_proc WHERE proname like
> geometryfromtext | 25
> geometryfromtext | 25 23
> geomfromtext | 25
> geomfromtext | 25 23
> pointfromtext | 25
> pointfromtext | 25 23
> linefromtext | 25
> linefromtext | 25 23
> linestringfromtext | 25
> linestringfromtext | 25 23
> polyfromtext | 25
> polyfromtext | 25 23
> polygonfromtext | 25 23
> mlinefromtext | 25 23
> mlinefromtext | 25
> multilinestringfromtext | 25
> multilinestringfromtext | 25 23
> mpointfromtext | 25 23
> mpointfromtext | 25
> multipointfromtext | 25 23
> mpolyfromtext | 25 23
> mpolyfromtext | 25
> multipolygonfromtext | 25 23
> geomcollfromtext | 25 23
> geomfromwkb | 17
> geomfromwkb | 17 23
> pointfromwkb | 17 23
> pointfromwkb | 17
> linefromwkb | 17 23
> linefromwkb | 17
> linestringfromwkb | 17 23
> polyfromwkb | 17 23
> polyfromwkb | 17
> polygonfromwkb | 17 23
> polygonfromwkb | 17
> mpointfromwkb | 17 23
> mpointfromwkb | 17
> multipointfromwkb | 17 23
> multilinefromwkb | 17 23
> mlinefromwkb | 17 23
> mlinefromwkb | 17
> mpolyfromwkb | 17 23
> mpolyfromwkb | 17
> multipolyfromwkb | 17 23
> geomcollfromwkb | 17 23
> (54 rows)
> gistest2=# SELECT oid, typname FROM pg_type WHERE typname = 'geometry'
> or typname='bytea' or typname='text';
> oid | typname
> 17 | bytea
> 25 | text
> 59166 | geometry
> (3 rows)
> Thank you for your nice advice!
> Koji Yano
> http://www.officeyano.net
> postgis-users mailing list
