[postgis-users] Query Performance Problem
Dirk Jesko
jesko at geocontent.de
Fri Feb 4 00:45:46 PST 2005
Hi Mark,
I finally managed to test the suggestions and put the boundary in a
separate table. The query time is now acceptable.
Thanks again for the suggestions,
Dirk
>Hi Dirk,
>Thanks for the information. I can't see anything too wrong with the query
>plans, other than that some times seem quite large for the Nested Loops. I'm
>still thinking it may be caused by the aggregate being used in your view;
>could you try the suggestion in my previous email and see if that improves
>things for you?
>Kind regards,
>Mark.
