[postgis-users] Converting WKT or WKB
Abe Gillespie
agillesp at vt.edu
Sun Feb 6 10:37:30 PST 2005
Hello all. I'm new to the list.
I've just started using PostGIS, I'm one from the MapServer crowd. I'd
like to use PostGIS with some ESRI technologies and am hoping to find
an easy way to go from PostGIS objects to ESRI objects.
My first idea is using Postgres native geometry types. The .Net data
connector (Npgsql) has support for these built in types. Are there any
PostGIS functions that will convert its types to Postgres geometry
types? I imagine things working sort of like:
string sql = "SELECT as_native_postgres_box(extent(the_geom)) FROM
shape_table";
NpgsqlCommand cmd = new NpgsqlCommand(sql, con);
NpgsqlBox box = (NpgsqlBox)cmd.ExecuteScalar();
The second idea is to just use a third party library to do the parsing
for me. I see there's a java one, but I'm looking for a .Net happy
library.
Also, and this is OT from the subject, but how do you specify to
PostGIS whether the geometries are stored as WKT or WKB? Mine are all
WKT and I'm curious in case down the road I want to use WKB.
Thanks for any help.
-Abe
