[postgis-users] About AddPoint(linestring, point, [<position>])
strk at refractions.net strk at refractions.net
Tue Feb 8 00:03:13 PST 2005
A LINESTRING with less then 2 points is invalid.
You might want to try the MakeLine() aggregate or
the LineFromMultiPoint() function.
You'll have to take care of ordering, for example:
SELECT MakeLine(the_geom) FROM ( SELECT the_geom FROM points
	ORDER BY time ) foo;
Note that MakeLine allows construction of single-point LineString.
This is not a design decision, so do not rely on it (we should probably
avoid that)
--strk;
On Mon, Feb 07, 2005 at 04:53:37PM -0700, Seamus Thomas Carroll wrote:
> Hi,
> I was hoping to use AddPoint to build a LINESTRING by adding POINTs from
> time to time.  A problem arrises because innitially i want an empty
> LINESTRING.  It appears i cant begin to add points until there are at
> least two points in the LINESTRING (for that matter i cant create a
> LINESTRING with less than two points).
> Is this by design or is it something that has not been needed up to this
> point?  Are there any suggestions on how i may accomplish this?
> Thanks,
> Seamus
> postgis-users mailing list
