[postgis-users] bugs in postgis-1.0RC2 with postgres 7.2.1
strk at refractions.net
Mon Feb 14 00:59:51 PST 2005
Alex, the diff is still too intermixed, if you can provide
smaller, single patches I'll check them out (each Makefile patch
still has references to the jar and doc work).
For the regression test scripts I don't like arbitrarily writing
to the caller's homedir. We can either use the /tmp/ dir or
require an argument to specify temporary directory. Also, we
could have a wrapper calling all three tests.
For the postgis_undef we probably need a different name as we did
with postgis.sql and lwpostgis.sql. Using the same name could
generate installations for which you have two enabler scripts
(for HWGEOM and LWGEOM) and a single disabler script (for unknown
version).
For the jdbc2 patch, DESTDIR is not defined:
/usr/src/postgresql/postgresql-8.0.0/config/install-sh: no destination specified.
make: *** [install] Error 1
For both jdbc and jdbc2 we might use multiple entries in the default
CLASSPATH, as I personally have postgreql.jar in /usr/share/java
(it's a woody) but not in the postgresql source tree..
I'm not sure about the best practice in this case: how much is the
jdbc driver bound to the specific postgresql version we are building
postgis against ?
--strk;
On Sat, Feb 12, 2005 at 02:49:08AM +0200, alex bodnaru wrote:
> hello strk,
> On Tue, 2005-02-08 at 08:57 +0100, strk at refractions.net wrote:
> > On Tue, Feb 08, 2005 at 05:57:47AM +0200, alex bodnaru wrote:
> > > i am attaching a diff of those changes i would propose for postgis, with
> > > no specific debian issue. please take a look.
> > Alex, neither the docs/ nor the jdbc2/ is guaranteed to work
> > on every machine. Attempting to build by them by default would
> > generate a lot of noise ...
> only the first diff directive is adding doc to the default all
> directive. all the others are only adding/fixing usual makefile
> features.
> as for the patches to the regression test scripts, they are meant to
> separate between writing rights to the source directory (developer user)
> and writing rights to the database (postgres user). it also leaves the
> source tree cleaner.
> best regards,
> alex
> postgis-users mailing list
