[postgis-users] View area
strk at refractions.net
Tue Feb 15 09:52:11 PST 2005
Intersection should do.
Don't use GeomFromText() with anything but OGC Well Known Text format.
Try something like this:
SELECT AsSVG(intersection(the_geom, setSRID('BOX3D(...)'::box3d,42102)))
WHERE the_geom && setSRID('BOX3D(...)'::box3d,42102);
--strk;
On Tue, Feb 15, 2005 at 10:47:32AM -0700, Sean M. Montague wrote:
> I sent this in response to the wrong post.
> The select statement below is close to what I'm looking for. I don't
> know if I'm imagining this, but I thought it was possible to define a
> box and extract just what is inside that box, clipping all that lies
> outside, including polygons. Is this possible using a different sql
> statement?
> SELECT AsSVG(the_geom,0,8) as the_geom FROM usa WHERE the_geom &&
> GeomFromText('BOX3D(-2243528 2679134,-1689106 2002338)'::box3d,42102);
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Sean
> M. Montague
> Sent: Monday, February 14, 2005 5:42 PM
> To: PostGIS Users Discussion
> Subject: [postgis-users] View area
> Is there a way to extract data based on viewable area coordinates. For
> instance, can I extract roads that are only within my viewer area, or
> part of a polygon, but not the whole thing? I've tinkered with
> intersection, but have failed to accomplish anything. Thanks.
> Sean
> postgis-users mailing list
