[postgis-users] Small speed comparison
Markus Schaber
schabios at logi-track.com
Thu Feb 17 07:09:45 PST 2005
Hi, strk,
strk at refractions.net schrieb:
>>But while comparing those results, I found some odd thing (that was
>>present before the current changes, too): I wonder why asEWKB and
>>asBinary both are noticably slower than rendering canonical text
>>(hexEWKB), though.
> asEWKB does not exist.
Hmm. My version of
-- $Id: lwpostgis.sql.in,v 1.113 2005/02/08 07:59:07 strk Exp $
contains a definition for
CREATE OR REPLACE FUNCTION AsEWKB(geometry)
RETURNS BYTEA
AS '/usr/lib/postgresql/lib//liblwgeom.so.1.0','WKBFromLWGEOM'
LANGUAGE 'C' IMMUTABLE STRICT; -- WITH (isstrict,iscachable);
at lines 1713-1716.
> asEWKT must write a string, so contains
> many sprinf calls that hexEWKB doesn't have.
> asBinary() drops SRID and higher dimensions, thus the slowdown.
I know that asEWKT has to be slower compared to the other versions (and
it is still about 8 times faster compared to PostGIS 0.X).
But I wondered why asBinary() and asEWKB() seem to be noticeably slower
compared to hexWKB output. I now noticed that the problem seems to be
related by function call overhead vs. implicit call of the output funciton:
lwgeom=# select geometry_out(geom) from adminbndy1;
Zeit: 7241,612 ms
Zeit: 7122,037 ms
Zeit: 7135,651 ms
lwgeom=# select geom from adminbndy1;
Zeit: 5638,356 ms
Zeit: 5624,068 ms
Zeit: 5604,034 ms
The second call implicitly calls geometry_out as this is the output
function of the geometry type. So calling a function on a row seems to
add a noticeable overhead.
Maybe I should discuss this on pgsql_performance list?
Just for curiosity, I did some additional tests:
lwgeom=# select noop(geom) from adminbndy1;
Zeit: 7259,772 ms
Zeit: 7230,494 ms
Zeit: 7199,697 ms
So calling noop() seems to introduce roughly the same overhead as
calling geometry_out() explicitly.
lwgeom=# select geometry_send(geom) from adminbndy1;
Zeit: 7002,951 ms
Zeit: 6965,926 ms
Zeit: 6962,790 ms
lwgeom=# select asEWKB(geom) from adminbndy1;
Zeit: 7002,905 ms
Zeit: 6967,374 ms
Zeit: 6958,801 ms
As you see, calling geometry_send and asEWKB are both slower than
canonical text output, but (as expected) faster than calling
geometry_out explicitly.
lwgeom=# select asBinary(geom) from adminbndy1;
Zeit: 7194,490 ms
Zeit: 7180,544 ms
Zeit: 7179,425 ms
And here you see the overhead introduced by force_2d() and SRID
dropping, which seems in the same range as hexEWKB vs EWKB, at least for
my 2-dimensional geometries.
Markus
markus schaber | dipl. informatiker
logi-track ag | rennweg 14-16 | ch 8001 zürich
phone +41-43-888 62 52 | fax +41-43-888 62 53
mailto:schabios at logi-track.com | www.logi-track.com
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050217/aae8314b/attachment.pgp>
