[postgis-users] Using exteriorring
Benoit Ogier
benoit.ogier at cbconseil.com
Fri Feb 18 11:46:45 PST 2005
thanks for your help...
i succed with the above request under 0.9.0.
Le 18 févr. 05, à 18:25, RIBOT, Nicolas a écrit :
>> ExteriorRing() returns a LINESTRING, as per OGC specifications.
>> Output column should be LINESTRING.
>> I'm sorry I forgot that, so you need another function to store
>> it as a polygon...
>> With postgis-1.0 you can use MakePolygon(ExteriorRing(...)).
>> With postgis-0.x I'm afraid you have no easy way (but other
>> users might give you better suggestions)
> Maybe using astext(ExteriorRing(...)) and the "substr" String function
> to
> generate a polygon textual representation from the linestring, by
> removing
> the "LINESTRING" keyword and replacing it with the "POLYGON" one and
> the
> extra set of parentheses. something like:
> geometryFromText('POLYGON(' || substr(astext(exteriorRing(...)), 10)
> <srid>)
> Nicolas
> Ribot<important_notice.txt>____________________________________________
> ___
> postgis-users mailing list
Benoît Ogier{
Carte Blanche Conseil
47, rue de Lancry
75010 Paris
Tel : +33 1 42 41 21 21
Fax : +33 1 42 41 70 40
email : benoit.ogier at cbconseil.com
