[postgis-users] Installing postgis-0.9.1
strk at refractions.net
Wed Feb 23 05:03:33 PST 2005
On Wed, Feb 23, 2005 at 12:47:47PM +0000, Shaq Gbadebo wrote:
> Thank you for your reply.
> 1. I did run make install from the postgis directory.
> 2. The libpostgis library is in the postgis directory.
make install should have installed it in the PostgreSQL
directory, not the PostGIS directory. Check to see if
it's there (should be in the directory printed by pg_config --pkglibdir).
--strk;
