[postgis-users] Installing postgis-0.9.1
Markus Schaber schabios at logi-track.com
Wed Feb 23 06:51:30 PST 2005
Hi, Shaq,
Shaq Gbadebo schrieb:
> I can not find that folder, in the postgresql directory. The only
> libpostgis file is in the postgis directory which is in the postgresql
> contrib folder.
What does "pg_config --pkglibdir" spit out on your machine?
On my machine, it says /usr/lib/postgresql/lib and this is where the
installed lipostgis.so.* files are expected to be. Postgis "make
install" copies them from the postgis build directory to this directory,
which usually already contains a lot of other .so files from postgresql
installation.
If this directory (the one pointed by pg_config) does not exist on your
machine, or pg_config does not work, then I suspect that there's
something wrong with your postgresql installation itsself.
Markus
markus schaber | dipl. informatiker
logi-track ag | rennweg 14-16 | ch 8001 zürich
phone +41-43-888 62 52 | fax +41-43-888 62 53
mailto:schabios at logi-track.com | www.logi-track.com
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050223/f646879a/attachment.pgp>
