[postgis-users] error compiling postgis-1.0.0-rc2
thierry.bertrand at equipement.gouv.fr
Fri Feb 25 01:49:08 PST 2005
Hello,
I didn't answered earlier, I was on holidays. Sorry.
I've tried to move this line as you said.
I've also tried to move it at the end of the file or somewhere else up.
I got the same message or I got a file missing.
> -----Message d'origine-----
> De : postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net]De la part de
> strk at refractions.net
> Envoyé : mercredi 16 février 2005 17:36
> À : postgis-users at postgis.refractions.net
> Objet : Re: [postgis-users] error compiling postgis-1.0.0-rc2
> This bug is getting annoying.
> That line uses the $(YACC) variable, which is initialized
> to 'yacc' in Makefile.config if undefined.
> I suspect postgresql Makefile are overriding it somehow
> as I found this problem when trying to compile against
> an older postgresql source.
> Try moving this line:
> include $(top_srcdir)/src/Makefile.shlib
> >From around line 98 of lwgeom/Makefile
> to line 108 (after FLEX and YACC are used).
> --strk;
> On Wed, Feb 16, 2005 at 05:27:57PM +0100,
> thierry.bertrand at equipement.gouv.fr wrote:
> > Hello,
> > I'm trying to compile postgis-1.0.0-rc2 on a Debian Sarge
> system with
> > postgresql 7.4.7-2.
> > I have compiled postgresql as written in README.postgis.
> > When I try to make in
> .../postgresql-7.4.7/contrib/postgis-1.0.0-rc2, I have
> > the following errors:
> > vd -p lwg_parse_yy wktparse.y
> > make[1]: vd: Command not found
> > make[1]: [wktparse.tab.c] Error 127 (ignored)
> > mv -f y.tab.c wktparse.tab.c
> > mv: cannot stat `y.tab.c': No such file or directory
> > make[1]: *** [wktparse.tab.c] Error 1
> > make[1]: Leaving directory
> > `/web/compils/postgresql-7.4.7/contrib/postgis-1.0.0-rc2/lwgeom'
> > make: *** [liblwgeom] Error 2
> > I have search for vd in Debian packages but I haven't found it.
> > I have tried with postgis-0.9.1, it works fine.
> > Any ideas ?
> > Thanks
> > postgis-users mailing list
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
