[postgis-users] Re: JDBC PreparedStatements and inserting geometries...
Corey Puffalt
cplists at gmail.com
Fri Feb 25 15:17:14 PST 2005
I discovered a solution (not sure if this is the best solution or not
-- maybe an expert could comment?) to my problem. That was to
parameterize everything inside the single quotes (as I had already
tried) and to wrap that inside a call to text(). I stumbled across
the text() method mentioned in another email in the archive... though
I haven't yet found documentation on what it does...
==========>8==========
String psqlInsertLine =
"INSERT INTO gis_table (id, attr1, geometry, attr2) " +
"VALUES (?, ?, GeometryFromText(text(?),4267), ?)";
PreparedStatement insertStmt = conn.prepareStatement(psqlInsertLine);
String geometry = getGeometry(attr1, attr2); // get a geometry based
on the attributes...
insertStmt.setObject(1, id);
insertStmt.setObject(2, attr1);
insertStmt.setObject(3, "'MULTILINESTRING ((" + geometry + "))'");
insertStmt.setObject(4, attr2);
insertStmt.executeUpdate();
==========8<==========
Corey
On Fri, 25 Feb 2005 14:33:43 -0700, Corey Puffalt <cplists at gmail.com> wrote:
> All,
> I'm having problems performing inserts of geometry in Java using a
> PreparedStatement. Here's what I'm attempting to do (stripped down
> for simplicity...error handling removed etc.):
> "VALUES (?, ?, GeometryFromText('MULTILINESTRING ((?))',4267), ?)";
> PreparedStatement insertStmt = null;
> insertStmt.setObject(3, "'MULTILINESTRING ((" + geometry + ))');
> geometry is a string like so: "-114.3252583 57.0771 ,-114.3227833
> 57.0313528 ,-114.3285083 56.9643194" for example.
> The particular example above results in a:
> org.postgresql.util.PSQLException: The column index is out of range:
> 4, number of columns: 3.
> The error occurs presumably because of the single quotes. How can I
> get around this? I've tried parameterizing everything between the
> single quotes but that doesn't work either...instead I get:
> java.sql.SQLException: ERROR: function geometryfromtext(character
> varying, integer) does not exist
> Is there anyway to use a PreparedStatement with geometries?
> Thanks,
> Corey
> PS: Is there a searchable archive of the mailing list somewhere?
