[postgis-users] distance_spheroid and index files
Jonas Wolf wolfey at gmx.net
Sun Feb 27 04:07:52 PST 2005
Thanks for all the replies.
I actually don't mind getting "kind of right" answers, so
distance_sphere seems like the right choice. However, for some reason
this function does not seem to exist. I installed PostgreSQL 7.3.4,
Proj4 4.4.9 and GEOS 2.1.1 on Mandrake Linux. I then downloaded Postgis
RC 3, updated the Makefile.config USE_PROJ and USE_GEOS variables, ran
make and make install, with no errors. I set up the database and ran
lwpostgis.sql on it. Now distance_sphere is available, as I said I've
been using it. But no distance_sphere. Does that make any sense?
Shouldn't this function be defined in lwpostgis.sql, like
distance_sphere? Because it's not in there. I'm quite confused, does
anybody have a clue what I might have done wrong?
Thanks, Jonas
Paul Ramsey wrote:
> Index usage is important. As strk notes, 4326 is measured in degrees, so
> you'll have to convert your radius to degrees in order to create the
> index bounding box.
> Also note that distance_spheroid is very accurate but VERY EXPENSIVE. If
> you don't mind getting "kind of right" answers, try the much faster
> distance_sphere, which is 10 times faster.
> Paul
