[postgis-users] Crasher in rc2
Markus Schaber schabios at logi-track.com
Mon Feb 28 08:06:32 PST 2005
Hi, Rod,
Rod Taylor schrieb:
> The below looks silly, but an export / import of an old view created the
> translated format. Either way, it probably should crash the database.
> bric=# select
> '0103000000010000000500000000000000008066C000000000008066C0000000000080664000000000008066C00000000000806640000000000080664000000000008066C0000000000080664000000000008066C000000000008066C0'::bric_extension.geometry;
> server closed the connection unexpectedly
>         This probably means the server terminated abnormally
>         before or while processing the request.
> The connection to the server was lost. Attempting reset: Failed.
This works for me with a rather fresh CVS checkout. So it could either
be fixed (could you try RC3?), or a platform dependend problem. Which
architecture and OS do you use?
Markus
markus schaber | dipl. informatiker
logi-track ag | rennweg 14-16 | ch 8001 zürich
phone +41-43-888 62 52 | fax +41-43-888 62 53
mailto:schabios at logi-track.com | www.logi-track.com
