[postgis-users] Possible issue with Geos on PostgreSQL 8.0 Na tive Windows
Obe, Regina DND\MIS
robe.dnd at cityofboston.gov
Wed Jan 12 08:11:15 PST 2005
GEOS 2.1.1
-----Original Message-----
From: strk at refractions.net [mailto:strk at refractions.net]
Sent: Wednesday, January 12, 2005 10:52 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Possible issue with Geos on PostgreSQL 8.0
Native Windows
Which GEOS version ?
--strk;
On Wed, Jan 12, 2005 at 09:40:52AM -0500, Obe, Regina DNDMIS wrote:
> I was doing a trial port of my data from Cygwin PostGreSQL 7.4
> Postgis 0.8
> To Native Windows PostGreSQL 8.0.0 RC4, postgis 0.9.
> 2 issues - these could be caused by something wrong with my
> reconfiguration since there are so many variables that have changed so
> not sure if they are problems or not. I just wanted to know if others
> have run into similar issues.
> When I was testing the geom_union function on one of my tables
> On the cygwin install I get the following behavior
> SELECT geomunion(the_geom) from neighborhood;
> results in Geos throwing the below error
> ERROR: GEOS union() threw an error!
> NOTICE: TopologyException: side location conflict
> (780343,2.95405e+06)
> select geomunion(the_geom) from neighborhoods where name
> IN('Dorchester', 'Charlestown');
> Results in
> SRID=102686;MULTIPOLYGON(((778278.699002388 .........
> Same Tests on the: Native Windows PostGreSQL 8.0.0 RC4, postgis 0.9.
> (I'm using the PostGIS that came packaged with 8.0.0 RC4 official
> release)
> Result: The postgres connection crashes without throwing an error so I
> need to reconnect.
> select geomunion(the_geom) from neighborhoods where name IN('Dorchester',
> 'Charlestown');
> Result - No SRID shows SRID=-1;MULTIPOLYGON(((778278.699002388
> Other functions such as collect for example return an SRID on both
installs
> and I checked the table and the geometry_columns table and both register
an
> SRID.
> I tried reloading the table from the original shape file using the newer
> shp2pgsql and the same error still stands.
> postgis-users mailing list
For standing up against patentability of software,
Thank You, Poland!
Read the intervention: http://kwiki.ffii.org/ConsPolon041221En
Send your thanks: thankyoupoland.info
Read/do more: http://www.noepatents.org/
