[postgis-users] Possible issue with Geos on PostgreSQL8.0NativeWindows
Mark Cave-Ayland
m.cave-ayland at webbased.co.uk
Thu Jan 13 03:25:53 PST 2005
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of strk at refractions.net
> Sent: 13 January 2005 10:42
> To: Steffen Macke
> Cc: PostGIS Users Discussion
> Subject: Re: [postgis-users] Possible issue with Geos on
(cut)
> > I'm using PostGIS as provided by PostgreSQL 8.0.0 RC5:
> > dcmms=# select geosnoop('POLYGON((0 0, 1 1,0 0))');
> > server closed the connection unexpectedly
> > This probably means the server terminated abnormally
> > before or while processing the request.
> > What does the "correct" output look like?
> No, it looks like this:
> strk=# select '130', geosnoop('POLYGON((0 0, 1 1, 0 0))');
> NOTICE: IllegalArgumentException: Number of points must be 0 or >3
> ERROR: POSTGIS2GEOS conversion failed
> strk=#
> --strk;
Hi guys,
OK, I just downloaded and installed PostgreSQL 8.0 RC5 but didn't install
the version of PostGIS that came with it - instead I used the latest
installer from http://www.webbased.co.uk/mca/ (PostGIS 0.9.0-ish, GEOS
2.0.1, PROJ 4.4.8):
dcmms=# select geosnoop('POLYGON((0 0, 1 1, 0 0))');
ERROR: Couldnt convert the postgis geometry to GEOS!
dcmms=#
So looks ok here.... Perhaps I missed some detail in the compilation
somewhere? Can anyone else recreate this?
Kind regards,
Mark.
WebBased Ltd
South West Technology Centre
Tamar Science Park
Plymouth
PL6 8BT
T: +44 (0)1752 791021
F: +44 (0)1752 791023
W: http://www.webbased.co.uk
