[postgis-users] Simplify() and direction dependency
strk at refractions.net
Thu Jan 13 08:23:19 PST 2005
Someone is working on PHP postgis classes, you might join
them and make that a PHP extension..
Of course if someone comes out with a C implementation that'll
be fine too, as another way of simplifying geoms.
--strk;
On Thu, Jan 13, 2005 at 05:08:38PM +0100, Andreas Neumann wrote:
> Hello!
> I successfully use Simplify() in my Postgis/SVG projects and found it to
> be very useful.
> It works fine for MULTILINESTRINGs/LINESTRINGs and POLYGONs that aren't
> part of a polygon mosaic. However, for polygon mosaics, I can't use the
> current Simplify() function because it is not direction independent.
> That means that for polygons that run in opposite directions we will get
> different results, resulting in sliver polygons.
> A colleague of mine explained me a direction independent generalization
> algorithm that would partially solve that problem. It would be slower
> though, than the Douglas-Poiker algorithm.
> That algorithm would not start with the start and endpoint of the line
> (as in the Douglas-Poiker algorithm), but would always look at three
> points at the time, move forward one vertex to the next three points and
> after looking through all coordinate-triples would first eliminate only
> the point in the triple with the lowest distance. In another iteration
> it would remove again the one with the lowest distance and so on, until
> all distances are longer than the tolerance. To speed up things one
> could store the distances in the first iteration in an array and only
> re-calculate the distances where the vertices in the neighbourhood change.
> I could further explain the algorithm and make an illustration if that
> is of interest.
> One problem that remains, is that in polygon mosaics one has to detect
> and flag the nodes where 2 or more polygons meet and remove those nodes
> from the list of removable points. Is there any way in current postgis
> to detect those nodes where polygon edges meet? I guess this would
> require a node/edge topology.
> I am personally not a C programmer but could make a prototype
> implementation in perl, if that would help. If another person that is
> able to make C contributions to Postgis could transfer this later, I
> would be willing to make such a prototype in Perl or PHP.
> What do you think? Is someone else working on something similar?
> Thanks for your ideas,
> Andreas
> Andreas Neumann - Department of Cartography
> Swiss Federal Institute of Technology (ETH)
> ETH Hoenggerberg, CH-8093 Zurich, Switzerland
> Phone: ++41-1-633 3031, Fax: ++41-1-633 1153
> e-mail: neumann at karto.baug.ethz.ch
> www: http://www.karto.ethz.ch/neumann/
> SVG.Open: http://www.svgopen.org/
> Carto.net: http://www.carto.net/
> postgis-users mailing list
For standing up against patentability of software,
Thank You, Poland!
Read the intervention: http://kwiki.ffii.org/ConsPolon041221En
Send your thanks: thankyoupoland.info
Read/do more: http://www.noepatents.org/
