[postgis-users] Function OVERLAPS() versus &&
strk at refractions.net strk at refractions.net
Fri Jan 14 10:46:37 PST 2005
On Fri, Jan 14, 2005 at 10:04:54AM -0800, James G Wilkinson wrote:
> Here is an example query:
> CREATE TALBE us_pophu_prj AS
>                SELECT a.gid, b.gid AS sec_gid,
> GEOMUNION(a.the_geom,b.the_geom)
>                FROM us_pophu a, us_tribes b
>                WHERE a.the_geom && b.the_geom AND
> OVERLAPS(a.the_geom,b.the_geom);
> My questions are as follows:
> (1) Are the use of the '&&' clause and the function OVERLAPS() redundant?
No. && only checks for bounding box overlap, overlaps() performs
topological overlap.
> (2) I know that '&&' will use the GiST index, but does the function
> OVERLAPS()
> use the GiST index?
No, only operators are allowed to use indexes.
> (3) Is the query I pose the most efficient way to union the two coverages?
You should probably avoid union of a geom with itself ...
AND a.gid != b.gid
--strk;
> Regards,
> Jim
> postgis-users mailing list
For standing up against patentability of software,
  Thank You, Poland!
Read the intervention:    http://kwiki.ffii.org/ConsPolon041221En
Send your thanks:         thankyoupoland.info
Read/do more:		  http://www.noepatents.org/
