[postgis-users] routing and network analysis
Justin Deoliveira
jdeolive at refractions.net
Tue Jan 18 17:01:04 PST 2005
Hi Robin,
I have built a network building/walking framework that is precisley for
solving problems like the one you describe. It is part of the geotools
project, in a module called "graph". See http://www.geotools.org/
The way it works is you pull all of the relevant geometries (in your
case road linestrings) out of the database and build a graph. Then walk
the graph to answer questions like give me the shortest path from node 1
to node 2.
The main drawback is that the entire graph has to be stored in main
memory. So if you are working with mass amounts of data then you might
need something a bit more elegant.
Let me know if you are interested and I can send you some sample code.
Justin
Robin Chauhan wrote:
> I have a PostGIS database of geographic points which I would like to
> find shortest paths between.
> a) I have access to road network data. I've heard the new GRASS can
> be used to do network analysis. anyone heard if it would be promising
> in combination with postGIS, or could suggest another package?
> b) as an alternative, can anyone suggest or point to an efficient
> approach for computing the shortest path between two points which does
> not go through, say, water polygons?
> thanks in advance,
> -Robin Chauhan
> postgis-users mailing list
Justin Deoliveira
Refractions Research Inc.
(250) 885-4387
