[postgis-users] Crash when calling distance_ellipsoid with PostGIS1.0rc1
Stephen Marshall
smarshall at wsi.com
Mon Jan 24 09:10:22 PST 2005
Calling the distance_ellipsoid function fails with PostGIS1.0rc1, where
is worked with PostGIS0.9.
In this example, the same call was made in two contexts, both using
PostgreSQL 8.0.0; the first with PostGIS 0.9 and the second with
PostGIS1.0rc1. In the latter case, the postgres backend server terminated.
PostGIS 0.9:
avdata_orig# select distance_spheroid(geometryfromtext('POINT(-77.122778
12.008611)', 4326), geometryfromtext('POINT(-89.656111 20.938056)',
4326), 'SPHEROID["WGS_1984",6378137,298.257223563]]'::spheroid);
distance_spheroid
1662043.58935675
(1 row)
PostGIS 1.0rc1:
avdata=# select distance_spheroid(geometryfromtext('POINT(-77.122778
server closed the connection unexpectedly
This probably means the server terminated abnormally
before or while processing the request.
The connection to the server was lost. Attempting reset: Failed.
I tracked the crash into the PostGIS function
LWGEOM_distance_ellipsoid_point(). It occurs at this call:
PG_LWGEOM *geom1 = (PG_LWGEOM *)PG_DETOAST_DATUM(PG_GETARG_DATUM(0));
By calling this function:
DatumGetPointer(PG_GETARG_DATUM(0));
I was able to determine that a valid (non-zero) address is being
returned for the Datum pointer, so I think the error occurs in the
PG_DETOAST_DATUM call.
My suspicion is that the data is being incorrectly identified as a
toasted value, and hence erroniously going through "detoasting" logic in
the postgres function pg_detoast_datum (found in
./src/backend/utils/fmgr/fmgr.c in the postgres distribution). However,
I have no inside knowledge of the postgres toasting code, so this is a
fairly naive guess.
Thanks for any help you can give.
Steve Marshall
