[postgis-users] PostgreSQL 7.3.x and 7.2.x
Mark Cave-Ayland m.cave-ayland at webbased.co.uk
Tue Jan 25 01:32:34 PST 2005
Hi Michael,
Yes it is possible. In my setup here I create individual users for each
version of PostgreSQL, e.g. pg74, pg80 and compile the source as each user
using a configure prefix similar to --prefix=/home/pg74/rel so that each
release is kept in it's own directory. I then add the ~/rel/bin and
~/rel/lib directories to the PATH for that particular user. For each user I
can then just use su, for example for PG 7.4 I can do "su - pg74" and then
initdb a fresh database cluster. Once this is completed it is simply a
matter of changing each postgresql.conf so that each version of PG listens
on a different port number and then starting the postgresql server using
pg_ctl as normal.
Hope this helps,
Mark.
WebBased Ltd
South West Technology Centre
Tamar Science Park
Plymouth
PL6 8BT
T: +44 (0)1752 791021
F: +44 (0)1752 791023
W: http://www.webbased.co.uk <http://www.webbased.co.uk/>
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
michael.vanderhoydonk at gim.be
Sent: 24 January 2005 21:15
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] PostgreSQL 7.3.x and 7.2.x
Hello,
We have a PostgreSQL 7.3.4 - PostGIS 0.8.2 - GEOS 1.0 database installed on
a linux machine.
I just wonder: is it possible to install Postgres/PostGIS version 7.2.x on
the same machine?
Thank you,
Michael Vanderhoydonk
GIS developer
G.I.M. - Geographic Information Management N.V.
Interleuvenlaan 5
B - 3001 HEVERLEE
BELGIUM
Tel. : +32 16 40 30 39
Fax : +32 16 40 69 39
michael at gim.be
 <http://www.gim.be/> http://www.gim.be
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050125/46f04949/attachment.html>
