AW: [postgis-users] MapServer and PostGIS 1 RC1 and RC2
Düster Horst
Horst.Duester at bd.so.ch
Thu Jan 27 00:39:03 PST 2005
strk
> What type is wkb_geometry ?
wkb_geometry is type of POINT
> Did you try manually issuing the query ?
> # SELECT asbinary(force_collection(force_2d(wkb_geometry)),'NDR')
> FROM avt_asit_unfall;
PostgreSQL responsed with
server closed the connection unexpectedly
This probably means the server terminated abnormally
before or while processing the request.
Dr. Horst Düster
GIS-Koordinator /Amtschef Stv.
Kanton Solothurn
Amt für Geoinformation
Abteilung SO!GIS Koordination
Werkhofstr. 65
CH-4509 Solothurn
Tel.: ++41 (0)32 627 25 32
Fax: ++41 (0)32 627 22 14
horst.duester at bd.so.ch
www.sogis.so.ch
-----Ursprüngliche Nachricht-----
Von: strk at refractions.net [mailto:strk at refractions.net]
Gesendet am: Donnerstag, 27. Januar 2005 09:29
An: Düster Horst
Cc: 'postgis-users at postgis.refractions.net'
Betreff: Re: [postgis-users] MapServer and PostGIS 1 RC1 and RC2
On Thu, Jan 27, 2005 at 09:03:18AM +0100, Düster Horst wrote:
> Now my third attempt to get an answer of my posted question.
> Since a time I'm playing with MapServer 4.4.1 and PostGIS 1RC1 and RC2
since
> today with semi
> success. I'm able to create maps with polygon and line layers from
PostGIS,
> but PostGIS/Postgres crashes with the error message (see below) when I
> use a point layer. This crash appears exclusively with all my point layers
> which work fine with MS 4.4.1 and Postgis 0.8. Do there exist any
> restrictions of using PostGIS 1 with MapServer 4.4.1??
> I would be appreciate about any hint.
> With best regards
> Horst
> Mapfile snippet:
> LAYER
> CONNECTIONTYPE POSTGIS
> CONNECTION 'dbname=xx host=xx user=xx port=5432'
> DATA "wkb_geometry from asit2 USING UNIQUE ogc_fid USING SRID=-1"
> TYPE POINT
--strk;
> Error message:
> > msDrawMap(): Image handling error. Failed to draw layer named 'asit2'.
> > msPOSTGISLayerWhichShapes(): Query error. Error executing POSTGIS SQL
> > statement (in FETCH ALL): DECLARE mycursor BINARY CURSOR FOR SELECT
ANZ_TOT::text,asbinary(force_collection(force_2d(wkb_geometry)),'NDR'),ogc_f
> > id::text from avt_asit_unfall WHERE wkb_geometry &&
> setSRID('BOX3D(588837.5
> > 213700,648462.5 261400)'::BOX3D, -1 ) -server closed the connection
> > unexpectedly This probably means the server terminated abnormally before
> or
> > while processing the request. Error with POSTGIS data variable. You
> > specified ''.
> > Standard ways of specifiying are :
> > (1) 'geometry_column from geometry_table'
> > (2) 'geometry_column from (<sub query>) as foo using unique <column
name>
> > using SRID=<srid#>'
> > Make sure you put in the 'using unique <column name>' and 'using SRID=#'
> > clauses in.
> > For more help, please see
http://postgis.refractions.net/documentation.php
> > Mappostgis.c - version of Jan 23/2004.
> Dr. Horst Düster
> Kanton Solothurn
> Werkhofstr. 65
> CH-4509 Solothurn
> www.sogis.so.ch
> postgis-users mailing list
