[postgis-users] MapServer and PostGIS 1 RC1 and RC2
strk at refractions.net
Thu Jan 27 03:17:37 PST 2005
I don't get the same result:
[lo:asbinary_crash]$ cat test.sql
select postgis_full_version();
create table test_pnt (id serial);
select addgeometrycolumn('public','test_pnt','wkb_geometry',-1,'POINT',2);
insert into test_pnt (wkb_geometry) values (Geometryfromtext('POINT(610000 230000)',-1));
SELECT asbinary(force_collection(force_2d(wkb_geometry)),'NDR') FROM test_pnt;
SELECT summary(wkb_geometry) from test_pnt;
[lo:asbinary_crash]$ psql -etf test.sql test
POSTGIS="1.0.0RC2" GEOS="2.1.1" PROJ="Rel. 4.4.8, 3 May 2004" USE_STATS DBPROC="0.1.0" RELPROC="0.1.0"
psql:test.sql:2: NOTICE: CREATE TABLE will create implicit sequence "test_pnt_id_seq" for serial column "test_pnt.id"
CREATE TABLE
public.test_pnt.wkb_geometry SRID:-1 TYPE:POINT DIMS:2
geometry_column fixed:0
INSERT 11512442 1
\001\007\000\000\000\001\000\000\000\001\001\000\000\000\000\000\000\000\240\235"A\000\000\000\000\200\023\014A
Point[]
What OS ? What postgresql version ?
Any warning at build time ?
--strk;
On Thu, Jan 27, 2005 at 12:02:18PM +0100, Düster Horst wrote:
> > You mean 'geometry', right ?
> Of course I meant type of geometry.
> > Also, did you dump/reload or manually upgrade postgis ?
> I created a new blank PostgreSQL-8.0.0 DB with:
> # createdb test
> # createlang plpgsql test
> # psql -d test -f lwpostgis.sql
> > Can you reproduce the bug on a single POINT geometry ?
> Here the steps that produces a single POINT geometry and leads to the server
> crash:
> # create table test_pnt (id serial);
> CREATE TABLE
> # select addgeometrycolumn('public','test_pnt','wkb_geometry',-1,'POINT',2);
> addgeometrycolumn
> (1 row)
> # insert into test_pnt (wkb_geometry) values (Geometryfromtext('POINT(610000
> 230000)',-1));
> INSERT 16691569 1
> # SELECT asbinary(force_collection(force_2d(wkb_geometry)),'NDR') FROM
> test_pnt;
> server closed the connection unexpectedly
> This probably means the server terminated abnormally
> before or while processing the request.
> > If you can show me summary(that_point)
> # select summary(wkb_geometry) from test_pnt;
> summary
> Point[]
> (1 row)
> Dr. Horst Düster
> GIS-Koordinator /Amtschef Stv.
> Kanton Solothurn
> Amt für Geoinformation
> Abteilung SO!GIS Koordination
> Werkhofstr. 65
> CH-4509 Solothurn
> Tel.: ++41 (0)32 627 25 32
> Fax: ++41 (0)32 627 22 14
> horst.duester at bd.so.ch
> www.sogis.so.ch
> -----Ursprüngliche Nachricht-----
> Von: strk at refractions.net [mailto:strk at refractions.net]
> Gesendet am: Donnerstag, 27. Januar 2005 09:44
> An: Düster Horst
> Cc: 'postgis-users at postgis.refractions.net'
> Betreff: Re: [postgis-users] MapServer and PostGIS 1 RC1 and RC2
> On Thu, Jan 27, 2005 at 09:39:03AM +0100, Düster Horst wrote:
> > strk
> > > What type is wkb_geometry ?
> > wkb_geometry is type of POINT
> > > Did you try manually issuing the query ?
> > > FROM avt_asit_unfall;
> > PostgreSQL responsed with
> If you can show me summary(that_point).
> --strk;
> > Dr. Horst Düster
> > Kanton Solothurn
> > Werkhofstr. 65
> > CH-4509 Solothurn
> > www.sogis.so.ch
> > Gesendet am: Donnerstag, 27. Januar 2005 09:29
> > An: Düster Horst
> > On Thu, Jan 27, 2005 at 09:03:18AM +0100, Düster Horst wrote:
> > > Now my third attempt to get an answer of my posted question.
> > > Since a time I'm playing with MapServer 4.4.1 and PostGIS 1RC1 and RC2
> > since
> > > today with semi
> > > success. I'm able to create maps with polygon and line layers from
> > PostGIS,
> > > but PostGIS/Postgres crashes with the error message (see below) when I
> > > use a point layer. This crash appears exclusively with all my point
> layers
> > > which work fine with MS 4.4.1 and Postgis 0.8. Do there exist any
> > > restrictions of using PostGIS 1 with MapServer 4.4.1??
> > > I would be appreciate about any hint.
> > > With best regards
> > > Horst
> > > Mapfile snippet:
> > > LAYER
> > > CONNECTIONTYPE POSTGIS
> > > CONNECTION 'dbname=xx host=xx user=xx port=5432'
> > > DATA "wkb_geometry from asit2 USING UNIQUE ogc_fid USING SRID=-1"
> > > TYPE POINT
> > --strk;
> > > Error message:
> > > > msDrawMap(): Image handling error. Failed to draw layer named 'asit2'.
> > > > msPOSTGISLayerWhichShapes(): Query error. Error executing POSTGIS SQL
> > > > statement (in FETCH ALL): DECLARE mycursor BINARY CURSOR FOR SELECT
> ANZ_TOT::text,asbinary(force_collection(force_2d(wkb_geometry)),'NDR'),ogc_f
> > > > id::text from avt_asit_unfall WHERE wkb_geometry &&
> > > setSRID('BOX3D(588837.5
> > > > 213700,648462.5 261400)'::BOX3D, -1 ) -server closed the connection
> > > > unexpectedly This probably means the server terminated abnormally
> before
> > > or
> > > > while processing the request. Error with POSTGIS data variable. You
> > > > specified ''.
> > > > Standard ways of specifiying are :
> > > > (1) 'geometry_column from geometry_table'
> > > > (2) 'geometry_column from (<sub query>) as foo using unique <column
> > name>
> > > > using SRID=<srid#>'
> > > > Make sure you put in the 'using unique <column name>' and 'using
> SRID=#'
> > > > clauses in.
> > > > For more help, please see
> > http://postgis.refractions.net/documentation.php
> > > > Mappostgis.c - version of Jan 23/2004.
> > > Dr. Horst Düster
> > > Kanton Solothurn
> > > Werkhofstr. 65
> > > CH-4509 Solothurn
> > > www.sogis.so.ch
> > > _______________________________________________
> > > postgis-users mailing list
> > > http://postgis.refractions.net/mailman/listinfo/postgis-users
